"DECORATION" layer definition (was: positioning an arbitrary
feature . . .)
Bob Basques
bob.basques at CI.STPAUL.MN.US
Fri Jan 27 14:58:18 EST 2006
Stephen,
I added a comment to #1547 (which applies directly to my problem)
I suggested something along the lines of a "decoration" layer
definition. Could even be implemented as a whole seperate file like
SYMBOLS, FONT, TEMPLATES etc. The idea would be to have a set of
parameter for decorating a map along the edges, at the corners,
arbitrary location (Fixed and Percentage based placements) of (Any
MapFile) elements, etc. This might even be a way of implementing a XML
version of a MAPFILE (which I've seen suggested a few time), This
decoration idea might be a way of luring folks over to the dark-side, I
mean to the new world of capabilities.
The more I think about it, the more possibilities I start coming up
with. If implemented with XML for example, it would be easy enough to
use for passing Markup back to the server in a similar format for
example, just pondering things . . .
I would like to suggest going the route of something XMLish in nature.
I'm available to talk some more of this through with anyone interested
as I think there would be a big audience for something like this.
I can live with what I have for right now though. :c)
bobb
Stephen Woodbridge wrote:
>Bob,
>I don't think you can. I tried to do this a while ago and eventually
>gave up. There are two bugs that you might want to look at and cc
>yourself to. You might also want to add this requirement to one of them.
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1592
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1547
>-Steve W.
>Bob Basques wrote:
>>All,
>>how can I position a feature like I can with a ScaleBar (POSITION LL).
>>I have an interface that doesn't use a static mapsize. The Scalebar
>>works great, but how can I postion abstract annotation in the same way,
>>by pushing things to the corners or edges (with the POSITION parameter)
>>This works for the Upper left:
>><cid:part1.08070209.07020003 at ci.stpaul.mn.us>
>> LAYER
>> NAME 'city_logo'
>> STATUS DEFAULT
>> TYPE POINT
>> TRANSFORM OFF
>> FEATURE
>> POINTS 33 65 END
>> END
>> CLASS
>> STYLE
>> SYMBOL 'city_logo'
>> SIZE 1
>> END
>> LABEL
>> TYPE bitmap END
>> END END
>> LAYER
>> NAME 'title'
>> STATUS DEFAULT
>> TYPE POINT
>> TRANSFORM OFF
>> FEATURE
>> POINTS 70 17 END
>> TEXT "GISmo"
>> END
>> CLASS
>> LABEL
>> TYPE truetype
>> FONT bluehigh
>> SIZE 20
>> POSITION CR
>> COLOR 0 0 0
>> OUTLINECOLOR 240 240 240
>> END
>> END
>> END
>>Thanks
>>bobb
