problem in compiling 4.8-rc3
Sean Gillies
sgillies at FRII.COM
Sun Jan 29 13:10:02 EST 2006
John,
From a quick peek at the configure script, looks to me that when you
specify --with-png, --with-jpeg, or --with-zlib paths, these
locations are searched for GD *before* the --with-gd location.
I've been avoiding this problem by not explicitly configuring --with-
png etc. I think that I see a potential fix for the configure script.
Wanna try something for me? On (or near) line 5666 change
LIBS="-lgd $GD_XTRA_LIBS -L$GD_LIBDIR $LIBS"
to
LIBS="-lgd -L$GD_LIBDIR $GD_XTRA_LIBS $LIBS"
We want the extra locations searched *after* the location you specify
with --with-gd. This seems to be tripping people up all of a sudden,
maybe there has been a recent change.
By the way, if you are using GDAL, you should configure --without-tiff.
cheers,
Sean
On Jan 29, 2006, at 10:14 AM, John Cartwright wrote:
> Thanks for your prompt reply, Sean!
> Strangely, the problem seems to be explicitly giving the location of
> some of the graphic libs (e.g. zlib, png, etc.) rather than letting
> them
> be found on their own). Fomerly the configuration looked like:
> ./configure --prefix=/extra/contrib/mapserver-4.8 \
> --with-freetype=/usr/bin/freetype-config \
> --with-zlib=/usr/lib \
> --with-png=/usr/lib \
> --with-jpeg=/usr/lib \
> --with-xpm=/usr/X11R6/lib \
> --with-gd=/extra/contrib/gd-2.0.33 \
> --with-proj=/extra/contrib/proj-4.4.9 \
> --with-geos=/extra/contrib/geos-2.1.1/bin/geos-config \
> --with-ogr=/extra/data/gdal-1.3.1/apps/gdal-config \
> --with-gdal=/extra/data/gdal-1.3.1/apps/gdal-config \
> --with-tiff=/usr/lib \
> --with-wfs \
> --with-wcs \
> --with-wmsclient \
> --with-wfsclient \
> --with-curl-config=/usr/bin
> If I pull the configure lines for tiff, png, jpeg, zlib; configure
> finds
> them in the system libs and seems to be OK. Does this make sense
> to you?
> Thanks again!
> -- john
> ----- Original Message -----
> From: Sean Gillies <sgillies at frii.com>
> Date: Sunday, January 29, 2006 6:25 am
> Subject: Re: problem in compiling 4.8-rc3
>> On Jan 29, 2006, at 12:23 AM, John Cartwright wrote:
>>> Hello All,
>>> I'm having a problem compiling 4.8 that seems to be related to the
>>> gdFontCacheSetup check:
>>> configure: checking where libiconv is installed...
>>> checking for iconv_open in -lc... no
>>> checking for libiconv_open in -liconv... no
>>> checking for libiconv_open in -liconv... yes
>>> using libiconv from system libs.
>>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>>> configure: checking for GD 2.0.16 or higher...
>>> checking for gdFontCacheSetup in -lgd... no
>>> configure: checking whether GD needs libiconv...
>>> configure: error: Could not find gd.h or libgd.la/libgd.so in
>>> /usr/local/graphicslibs/lib. Make sure GD 2.0.16 or higher is
>>> compiled
>>> before calling configure. You may also get this error if you didn't
>>> specify the appropriate location for one of GD's dependencies
>>> (freetype,
>>> libpng, libjpeg or libiconv).
>>> I'm using the same gd-2.0.33 and configuration line that compiled
>>> successfully for 4.6.0.
>>> I've been able to replicate the problem on both a RedHat ES3 amd
>>> Mac OS
>>> 10.4 system.
>>> Thanks for any help!
>>> -- john
>> Hi John,
>> Thanks for trying out the release candidate! It configures and
>> builds
>> for me with no problems. My Fedora system has GD 1.8.4 in /usr/lib,
>> and I have GD 2.0.33 installed at /usr/local/lib. To keep the
>> configuration straight I make sure to specify --with-gd=/usr/local.
>> cheers,
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://zcologia.com/news
Sean Gillies
