Overlapping labels
krishna S
kris_rock82 at YAHOO.COM
Mon Jan 30 10:38:37 EST 2006
Hello all, i have a question about overlapping labels in a map. I am trying
to label 3 different layers of a map, the problem is they are overlapping
on each other, then i set the position for all the three labels using the
position attribute in the label feature but still i couldnt get all the
three labels get displayed line after line. There is just this one point
where i am unable to set the label position(because others dont overlap). I
set the offset and checked if it works but when the map is zoomed in or
zoomed out it all screws up.
Is there a way that i can set the label position so that it doesnt get
affected though i change the map extent.
Thanks for your time ....
--kris
