Better TIF image rendering?
Frank Warmerdam
warmerdam at POBOX.COM
Tue Jan 31 07:58:48 EST 2006
On 1/31/06, Luca Manganelli <luca76 at gmail.com> wrote:
> Hi, I wonder if there is the possibility to have a better TIF rendering.
> We have ECW ortophotos, converted in TIF for more speed.
> But if we see entire map in ECW, the quality is far better than TIF.
> I think that the ECW module applies an antialiasing system, while TIF
> doesn't.
> Is there a way to improve rendering quality for TIFs?
Luca,
I would suggest pre-building overviews for the TIFF, and using
the averaging option as opposed to the default which is just
decimation. You would use a command like the following to
build overviews with averaging.
gdaladdo -r average abc.tif 2 4 8 16 32 64
Generally speaking averaging will give "smoother" results at
overview levels than the default decimation technique for building
overviews. If you have no overviews, implicit decimation is done.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
