Mapscript mapObj.save() to write out multiple outputformats
Shoaib Burq
hydromap at GMAIL.COM
Mon Jul 3 04:46:23 EDT 2006
Humm... not so sure if the map.draw applies to what we are trying to
do... according to the Mapscript API docs map.draw() returns an
imageObj, while we are trying to write-out a mapfile with multiple
outputFormat definitions in it.
This functionality should be part of the map.save() method but I am
beginning to think it's not implemented.
On 7/3/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> You probably have to loop over all the formats you need and for every
> format do something like:
> map.setOutputFormat
> map.draw
> hth,
> Umberto
> On 7/1/06, Shoaib Burq <hydromap at gmail.com> wrote:
> > Hi all
> > we are trying to create a mapfile on the fly and need to add multiple
> > outputformats to the mapfile. we can use the
> > appendOutputFormat(new_OF) in python-mapscript. However when using the
> > mapObj.save(mymapfile.map) to write our map object to file, it only
> > writes-out the last format appened.
> > The only relavent code i found was in:
> > mapserver/mapscript/python/tests/cases/outputformattest.py
> > But this only tests if the current outputformat is defined correctly ...
> > Does anyone know if we can use the mapObj.save() function to create
> > mapfiles with multiple OUTPUTFORMAT definitions and if not anyone know
> > where the save() function's defined and if its easy to extend it to do
> > this?
> > thanks heaps
> > shoaib
> > http://nomad-labs.com
