Cascading WMS - WFS
Barend Köbben kobben at ITC.NL
Mon Jul 3 07:43:22 EDT 2006
this seems to have to do with the settings of IMAGEPATH and IMAGEURL in the WEB object in your mapfile. The WFS stores it's GML there (using the IMAGEPATH) for the WMS to retrieve (using either the IMAGEURL or IMAGEPATH, not entirely clear to me). Somewhere in the docs is a note that this should probably change, as it exposes the GML to malicious downloading, but at the moment it's like that.
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Fabio D'Ovidio
> Sent: 30 June 2006 15:53
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Cascading WMS - WFS
> Dear ML,
> I have a problem.
> Some Months ago I have configured MapServer as WMS service
> where one layers was taken from another apServer configured as WFS.
> It worked fine and i was able to display gml format returned
> ny WFS MapServer as an image in WMS MapServer !
> Now I have tried to request for the same map and I have
> received the following error :
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msHTTPExecuteRequests(): HTTP request error. Can&#39;t open
> output file
> \\naru04\Inetpub\wwwroot\applicazioni\tmp\b4b1804569004f917244
> a03b13bd0963.tmp.gml.
> msBuildWFSLayerPostRequest(): WFS connection error. Metadata
> wfs_service must be set in the layer
> </ServiceException>
> </ServiceExceptionReport>
> I have tried also to set metadata wfs parameters in the layer
> and not in the CONNECTION tag but it's the same !!!
> why ?
> Thanks
> graphic
> Eng. Fabio D'Ovidio
> WebGIS Staff
> Planetek Italia Srl
> via Massaua, 12 - 70123 Bari - Italy
> web : http ://www.planetek.it
> e-mail : dovidio at planetek.it
