Mapscript mapObj.save() to write out multiple outputformats
Shoaib Burq
hydromap at GMAIL.COM
Mon Jul 3 12:16:10 EDT 2006
ok all done, I've also added a script to reproduce the problem
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1816
thanks Frank
On 7/3/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Shoaib Burq wrote:
> > Hi all
> > we are trying to create a mapfile on the fly and need to add multiple
> > outputformats to the mapfile. we can use the
> > appendOutputFormat(new_OF) in python-mapscript. However when using the
> > mapObj.save(mymapfile.map) to write our map object to file, it only
> > writes-out the last format appened.
> > The only relavent code i found was in:
> > mapserver/mapscript/python/tests/cases/outputformattest.py
> > But this only tests if the current outputformat is defined correctly ...
> > Does anyone know if we can use the mapObj.save() function to create
> > mapfiles with multiple OUTPUTFORMAT definitions and if not anyone know
> > where the save() function's defined and if its easy to extend it to do
> > this?
> Shoaib,
> I think this is a bug. If you could submit a bugzilla entry on this and
> ensure it is assigned to me I'll look into fixing it. At least in 4.9.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
