Problem plotting Age column on a dbf database
Tyler Mitchell
tylermitchell at SHAW.CA
Mon Jul 3 22:44:46 EDT 2006
On 3-Jul-06, at 4:54 PM, Willian Rampazzo wrote:
> I'm implementing a new project and i'm having some problems
> plotting an Age column from a dbf
> database like a label.
> First problem is: The column have a lot of zeros values and these
> values don't need to be plotted. Is
> there a way to specify it at the map file ?
Hi William,
I'd create a second layer that is only for the annotation. Then you
can add a WHERE clause in your CONNECTIONSTRING to only include
values > 0.
> Second problem is: When i plot the values, it is ploted on
> scientific notation. Is there a way to specify
> it to plot values like %3.2f notation ?
You could try to find what the postgresql function you need to do the
conversion, then explicitly request that field, with that function in
your CONNECTIONSTRING as well. Casting/converting the field using
the NUMERIC function allows you to specify scale and precision like %
3.2f does.
For example,
"the_geom, age::numeric(3,2) as AGE FROM mypoints where age >0;
Probably a better way, but I thought I'd through a quick idea out to
you.
Good luck,
Tyler
