R: [UMN_MAPSERVER-USERS] Oracle10g and queryByAttributes
Antonio Iandolo
aiandolo at GRUPPOAS.IT
Wed Jul 5 09:42:39 EDT 2006
I've changed my idcolumn to NUMBER(16) but it still doesn't work...and I
already have defined a UNIQUE INDEX on that column...
Moreover the same script works fine both with ESRI shapefiles and with
MapInfo tables...
Now some further questions:
1) I query (queryByAttributes) on a POINT layer and there is another
POINT layer for the same oracle table (in order to handle different
symbols for different zoom levels); each of these layers has 2 classes
(one for the selected point and one for all the other "unselected"
points): do you think this could be a problem for the queryByAttributes
method?
Of course only one layer is queried, depending on the zoom level....
Other suggestions to solve this problem?
Thanks again,
Antonio
> > I've tried all the following settings, getting always the
> same result
> > (shapeindex < 0):
> > DATA "GEOM FROM mytable USING UNIQUE idcolumn SRID 8307
> FILTER" DATA
> > "GEOM FROM mytable USING UNIQUE SRID 8307 FILTER" DATA "GEOM FROM
> > mytable USING UNIQUE SRID 8307 VERSION 10g FILTER"
> > The query returns 1 shape (i.e. $layer->getNumResults() = 1), but
> > after these statements
> > $layer->open();
> > $result=$layer->getResult(0);
> > I do a simple var_dump($result) and I get:
> > result=object(stdClass)(3) { ["shapeindex"]=> int(-2028233538)
> > ["tileindex"]=> int(-1) ["classindex"]=> int(0) }
> > That is $result->shapeindex < 0!! So the following $shape
> is "False":
> > $shape=$layer->getShape(-1,$result->shapeindex);
> > ...I don't think that $result->shapeindex should be negative...
> > My software environment is:
> > - Windows XP Professional SP1
> > - Apache 2.0.55
> > - MapServer 4.8.3
> > - php 4.4.3-dev (MS4W 1.5.3)
> > - php_mapscript_48.dll (232Kb - 09/05/2006 17.22)
> > - Oracle10g (XE)
> > I have both Oracle8i and Oracle10g installed (server and
> client), but
> > I've renamed the Oracle8i's home directory.
> > May I know your MapServer version, Php version and php_mapscript's
> > version (maybe also php_mapscript.dll's size and date)? Maybe the
> > problem is the php's "dev" version...(I'll "downgrade" to a stable
> > version)
> > Any further hint?
> > Thanks in advance,
> > Antonio
> >> Hi Antonio,
> >> How did you defined your DATA parameter for you layer?
> >> The extents for your query are right?
> >> Here I use this code as example:
> >> // Performing the query and returning only a single record
> >> @$qlayer->queryByAttributes($nm_field_query, $regex,
> >> MS_SINGLE);
> >> $numresults = $qlayer->getNumResults();
> >> if ($numresults > 0)
> >> for($f = 0; $f < $numresults ; $f++)
> >> // Opening the layer to return data
> >> $qlayer->open();
> >> // Getting the object that store
> the results
> >> $indexResult = $qlayer->getResult($i);
> >> $qresult =
> >> $qlayer->getShape(-1,$indexResult->shapeindex);
> >> // Getting the data from object
> >> // The "values" contains the data
> >> // for all columns that are in layer
> >> data definition
> >> // You can get all columns that are
> >> in data definition
> >> $dataResult =
> array($qresult->values[STATE]);
> >> // Cleaning and closing objects
> >> $qresult->free();
> >> $qlayer->close();
> >> return $dataResult[0];
> >> And my DATA definition:
> >> data "geo_column from (SELECT geo_id, state, totpop,
> >> geo_column FROM tb_states) USING UNIQUE geo_id FILTER"
