Tolerance and toleranceunits not working with CGI request?
Jelmer Baas
baas at SPEERIT.NL
Thu Jul 6 08:09:41 EDT 2006
Hi all,
I finally have some of my distance stuff up and running, but now I'm
stuck with getting the nearest point on my map.
This works:
mapserv.exe?mode=query&map=nearest.map&imgext=-70000+278750+400000+631250&mapxy=185382.700+444989.600&layers=TABAP&qlayer=TABAP&tolerance=999999&toleranceunits=meters
But this doesn't
mapserv.exe?mode=query&map=nearest.map&imgext=-70000+278750+400000+631250&mapxy=164018.5+451343.9&layers=TABAP&qlayer=TABAP&tolerance=9999999999999&toleranceunits=kilometers
This is my map file:
MAP
name nearest
STATUS ON
SIZE 640 480
UNITS meters
EXTENT -274506.825920 199616.266937 553854.848094 752598.058799
PROJECTION
"+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.87
03473836068,4.0812 +no_defs +to +proj=latlong +datum=WGS84"
END
LAYER
NAME TABCAB
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "data\TABCAB.TAB"
STYLEITEM "AUTO"
CLASS
NAME "Kabel"
TEMPLATE "nearest.html"
END
MINSCALE 1
MAXSCALE 4000000
END
LAYER
NAME TABAP
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "data\TABAP.TAB"
CLASS
END
END
END # Map File
This should yield results, shouldn't it?
Hopefully anyone can provide me with an answer.
With kind regards,
Jelmer Baas
