compiling MapServer in Win XP
Francesco Sozzi
fsozzi at INTERCAD.CH
Fri Jul 7 03:44:04 EDT 2006
Hi Giuseppe,
Time ago I had the same need and, yes, I had to modify map.h and compile
myself.
But I've never experimented your problem. I've just looked for iconv.h in my
files and I did not find.
Here you are my mapserver options (these does not require iconv.h):
MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
I've also seen you're using VC6. I had many troubles with this compiler in
Windows environment (I also use Win XP).
I work better with VC7.
Regards
Francesco
PS: do you really need so many layers?... For instance in my case I had a
customer that wanted to separately load 600 rasters. Now he loads all
rasters in only one layer with tile index tecnique.
----- Original Message -----
From: "Giuseppe De Rossi" <giuseppe.derossi at EMAIL.IT>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, July 07, 2006 9:06 AM
Subject: [UMN_MAPSERVER-USERS] compiling MapServer in Win XP
> Hi to everybody,
> this is for me the first one, hoper I'm not offtopic.
> I need a kind help in order to compile mapserver to increase the maximum
> number of allowed layers.
> I'm trying to compile it in winxp environment by using VC++6, I've
> downloaded the libraries and compiled them ( seems ok) but when I try to
> compile the server I get an error: Can't open the file iconv.h.
> I've installed cygwin and this file is in c:\cygwin\something.
> Now I'd like to know:
> how can I solve the missing of iconv.h, is that the evidence that my
> compiling process is wrong or my environment is not able to do ?
> is this file linked to a library ?
> to manage 800 layers, must I compile the mapserver and change the map.h ?
> is
> there another easier way to get it ?
> Thanks in advance and best regards
> Giu
> Email.it, the professional e-mail, gratis per te: http://www.email.it/f
> Sponsor:
> Scopri RIS il sistema di ricarica infinita. Meglio delle cartucce, meglio
> degli inchiostri, economico, facile da installare e da utilizzare, solo su
> refill.it
> Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=5191&d=20060707
