compiling MapServer in Win XP
Giuseppe De Rossi
giuseppe.derossi at EMAIL.IT
Fri Jul 7 20:01:49 EDT 2006
Hi Francesco,
thanks for you kind answer; now what drives me crazy is that I can't choose
the
compiling options. If I comment some code lines in make.opt file the result
id always the same: for example now I'd like to disable the Ming compiling
option but in both the situations in the make.opt:
MING=-DUSE_MING_FLASH
MING_DIR=$(MS_BASE)..ming-0.2a
and
# MING=-DUSE_MING_FLASH
# MING_DIR=$(MS_BASE)..ming-0.2a
the result is an error becouse the ming.h file is not found.
I've solved th iconv.h error by installing the right directory.
Now How do I have to do to disable an option, what file do I have to edit ?
Excuse me for the trivial questions.
Thanks
PS, I'm yet using VC6.
--------- Original Message --------
Da: Francesco Sozzi <fsozzi at INTERCAD.CH>
To: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Oggetto: Re: [UMN_MAPSERVER-USERS] compiling MapServer in Win XP
Data: 07/07/06 09:45
> Hi Giuseppe,
> Time ago I had the same need and, yes, I had to modify map.h and compile
> myself.
> But I've never experimented your problem. I've just looked for iconv.h in
my
> files and I did not find.
> Here you are my mapserver options (these does not require iconv.h):
> MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
> DEBUG=MSDEBUG
> I've also seen you're using VC6. I had many troubles with this compiler in
> Windows environment (I also use Win XP).
> I work better with VC7.
> Regards
> Francesco
> PS: do you really need so many layers?... For instance in my case I had a
> customer that wanted to separately load 600 rasters. Now he loads all
> rasters in only one layer with tile index tecnique.
> From: "Giuseppe De Rossi" <giuseppe.derossi at EMAIL.IT>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Friday, July 07, 2006 9:06 AM
> Subject: [UMN_MAPSERVER-USERS] compiling MapServer in Win XP
> > Hi to everybody,
> > this is for me the first one, hoper I'm not offtopic.
> > I need a kind help in order to compile mapserver to increase the maximum
> > number of allowed layers.
> > I'm trying to compile it in winxp environment by using VC++6, I've
> > downloaded the libraries and compiled them ( seems ok) but when I try to
> > compile the server I get an error: Can't open the file iconv.h.
> > I've installed cygwin and this file is in c:cygwinsomething.
> > Now I'd like to know:
> > how can I solve the missing of iconv.h, is that the evidence that my
> > compiling process is wrong or my environment is not able to do ?
> > is this file linked to a library ?
> > to manage 800 layers, must I compile the mapserver and change the map.h
> > is
> > there another easier way to get it ?
> > Thanks in advance and best regards
> > Giu
> > Email.it, the professional e-mail, gratis per te: http://www.email.it/f
> > Sponsor:
> > Scopri RIS il sistema di ricarica infinita. Meglio delle cartucce,
meglio
> > degli inchiostri, economico, facile da installare e da utilizzare, solo
su
> > refill.it
> > Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=5191&d=20060707
Sponsor:
Video Lezioni Gratis? Internet, Informatica, Hobby direttamente da
professionisti. Scopri adesso come imparare senza fatica e stress!
Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=5147&d=20060708
Sponsor:
Video-Corsi.com : Vuoi scoprire un modo rapido e veloce per imparare?
Scopri i nostri VideoCorsi professionali
Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=5141&d=20060708
