compiling MapServer in Win XP
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Sun Jul 9 07:09:33 EDT 2006
Giuseppe De Rossi wrote:
> Hi I've installed VC7 and cut most of libraries in the make.opt file so to
> obtain the simplest version possibile.
> After a lot of test now I got:
> LINK : warning LNK4044: unrecognized option "libjpeg.lib"; ignored
> LINK : warning LNK4044: unrecognized option "objs/freetype2110.lib"; ignored
> LINK : warning LNK4044: unrecognized option "gdal_i.lib"; ignored
> LINK : warning LNK4044: unrecognized option "libcurl.lib"; ignored
> LINK : warning LNK4044: unrecognized option "src/libming.lib"; ignored
> LINK : warning LNK4044: unrecognized option "lib/pdflib.lib"; ignored
> "src/interfaces/libpq/release/libpqd
> ll.lib"; ignored
> Creating library mapserver_i.lib and object mapserver_i.exp
> regex.obj : error LNK2001: unresolved external symbol _printchar
> libmap.dll : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: 'link' : return code '0x460'
> Stop.
> now what drives me crazy is that I can't
> choose
>> the
>> compiling options. If I comment some code lines in make.opt file the
> result
>> id always the same: for example now I'd like to disable the Ming compiling
>> option but in both the situations in the make.opt:
>> MING=-DUSE_MING_FLASH
>> MING_DIR=$(MS_BASE)..ming-0.2a
>> and
>> # MING=-DUSE_MING_FLASH
>> # MING_DIR=$(MS_BASE)..ming-0.2a
>> the result is an error becouse the ming.h file is not found.
>> I've solved th iconv.h error by installing the right directory.
>> Now How do I have to do to disable an option, what file do I have to edit
Giuseppe,
there still seem to be some problems with your makefile - you shouldn't
get any "unrecognized option" warning when compiling.
Besides, it looks like there are some issues when linking with the regex
library provided that this is not a side effect of some other error
somewhere else. This could however be a problem with VC7 since, as far
as I know, people out there have experienced some troubles
compiling/linking regex with recent versions of Visual C (after VC6),
but I might be wrong on that and this could in particular not apply to VC7.
However, I personally have always been successfully compiling Mapserver
with VC6, so, given the errors you reported in an earlier post, I
suggest you have a closer look at your makefile, and especially at your
nmake.opt file. For instance, I noticed that you were referring to a non
existent make.opt file. Note that this file is actually called nmake.opt
including the leading "n". If you feel like the options from that file
are ignored by the compiler, check its filename (nmake.opt) and do a
clean (nmake /f makefile.vc clean) immediately after any change to that
file.
I would add some obvious suggestions like checking you are in the right
directory, you are editing the right file etc. Too often things go wrong
due to some really silly mistakes. You might want to unpack Mapsever to
a different directory and start from scratch paying attention to every
detail.
Hope this helps.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
