multiple outputformats get lost when saving MAP file
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Jul 10 02:25:28 EDT 2006
I actually found out the problem is not with saving but with *cloning* a MAP file/object.
I have opened up a bug report which has a test script in PHP to reproduce. Hopefully somebody can look into this.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1823
Thanks in advance.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Eijnden, Bart van den (AGI)
Verzonden: maandag 10 juli 2006 7:58
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] multiple outputformats get lost when
saving MAP file
Hi list,
using PHP/Mapscript 4.8.3 I am loading a MAP file which has multiple (3) output formats, and after doing some modifications, I save the MAP object again.
The problem is, only one of the outputformats makes it into the resulting MAP file.
Is this by any chance related to:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1816
Best regards,
Bart van den Eijnden
drs. A.J. van den Eijnden
adviseur
Productteam Applicaties Geo-Informatie
Rijkswaterstaat Adviesdienst Geo-informatie en ICT
Postbus 5023, 2600 GA Delft
Derde Werelddreef 1, 2622 HA Delft
Telefoon: (015) 275 75 75
E-mail b.vdeijnden at agi.rws.minvenw.nl
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
Disclaimer
