.DM File Format
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Mon Jul 10 06:53:34 EDT 2006
Is this a table with X and Y values?
If so, once you have it in Access you can set up OGR Virtual Spatial Data
(an ovf file) for your Access table. See also:
http://iweb.gdal.org/ogr/drv_vrt.html
Ogr can output shapefiles so using the ogr2ogr utility you can transform
the data to a point shp.
Bart
> Thank you Stephen.
> This is probably out of the scope of the list, but do you know if there is
> there a way to convert them to Shape files?
> Thank you again.
> Tom
> ----- Original Message -----
> From: Stephen Kelly
> To: 'Thomas Hammerlund' ; MAPSERVER-USERS at LISTS.UMN.EDU
> Sent: Monday, July 10, 2006 7:43 PM
> Subject: RE: [UMN_MAPSERVER-USERS] .DM File Format
> Tom,
> MS Access can import Paradox (.db) files
> Stephen Kelly
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Thomas Hammerlund
> Sent: Monday, 10 July 2006 6:15 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] .DM File Format
> Hi Everyone,
> I have some data in .dm format. I have never seen this beofre but
> here's
> what I've found:
> It's a format from a company called Borland Software, and there's some
> kind of database viewercalled Paradox to view the data.
> Has anyone seen this file format before, or does anyone know where/how I
> can download the db viewer? It's a file called "pdxwin32.exe", but Google
> isn't being kind today.
> Thank you,
> Tom
