problem: compiling mapserver on windows
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jul 10 09:40:44 EDT 2006
Thibaut Le Pape wrote:
> Hello everyone,
> I tried to compile mapserver under windows, so I installed all the
> librairies needed and I get this error message (I use Visual Studio 8 to
> compile it):
> LIBC.lib(crt0dat.obj) : error LNK2005: __cinit already defined in
> LIBCMT.lib(crt
Thibaut,
The above message indicates you are linking in two different versions of
the standard C library. In your case the "default" c library (libc.lib),
and the multi-threaded version (libcmt.lib). This normally occurs when
some of the obj files being linked in are built with /MT and some are not.
Assuming you are consistently using (or not using) /MT, then it is likely
due to linking in a static .lib file from a supporting package that
is compiled differently.
My suggestions are:
o Make sure /MT is consistently being used in compiling mapserver. I
can't think of any reason this wouldn't be the case assuming you are
using the normal nmake makefiles.
o Try removing dependencies from as many external libraries as possible,
to establish which library is causing the conflict.
o Give up and use someone elses binaries... :-)
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
