Does Mapserver 4.8.3 work with windows 2000 and IIS 5
Andrew Krakowski
andrew at REFRACTIONS.NET
Mon Jul 10 19:01:32 EDT 2006
Hi Kris,
Have you been able to generate the "No query information to decode.
QUERY_STRING is set, but empty." message?
Have you read the online IIS MapServer instructions? There are a couple
you can find.
I'm not sure the difference between IIS 5 and 6 but I've succeeded with
MapServer 4.8.3 working on IIS 6.0 on XP.
Create a cgi-bin directory in your Inetpub directory and copy the
contents of the ms4w\Apache\cgi-bin directory into it.
In IIS add this directory as a virtual directory to your web-site.
Right-click Properties under the cgi-bin Virtual Directory and select
Scripts and Executables for Executables permission in the Virtual
Directory Tab.
When you right click the mapserv.exe file in IIS and select Browse in
IIS you should get the above message.
Hope that helps; if not let me know.
Andrew
rock well wrote:
> Hi all, i have posted this question earlier but had to luck ..... i have been trying to configure mapserver -4.8.3 on a windows 2000 machine with IIS 5. I tried different options like just having the basic libraries like proj,GD, regex. When i try to generate a map i always get a
> CGI Error
> The specified CGI application misbehaved by not returning a complete set of HTTP headers. The headers it did return are:
> i tried it from php mapscript, from a normal html file same result .....
> i dont know what wrong am i doing .... if anyone have configured mapserver with this configuration can you please suggest me, or any information might help ...
> Thanks a lot for your time,
> kris
> Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
Andrew Krakowski
Programmer, Refractions Research Inc.
