WMS getCapabilities and SRS
Sture Dingsøyr candalt at ONLINE.NO
Wed Jul 12 03:13:50 EDT 2006
Hi
I have a question regarding the SRS tag in getCapabilities.
In my mapfile I put all the EPSG codes that I want my layers to be available in with the METADATA tag ?wms_srs?, so that my layers look like this:
LAYER
            PROJECTION
                        "init=epsg:32633"
            END
            METADATA
                        "wms_title"        "Fylke flate"
                        "wms_srs"        "EPSG:4326 EPSG:25831 EPSG:25832 EPSG:25833 EPSG:25834 EPSG:25835 EPSG:27391 EPSG:27392 EPSG:27393 EPSG:27394 EPSG:27395 EPSG:27396 EPSG:27397 EPSG:27398 EPSG:32631 EPSG:32632 EPSG:32633 EPSG:32634 EPSG:32635 EPSG:102132 EPSG:102133 EPSG:102134 EPSG:102135"
                        "wms_abstract"                                     "For å hente dette tema via WMS må ein nytte layer_74 som verdi i LAYER parameter"
                        "gml_include_items"                  "all"
            END
            DATA "adaptive/74"
            STATUS off
            TRANSPARENCY 50
            TYPE polygon
            DUMP TRUE
            TEMPLATE "TRUE"
            NAME "layer_74"
            CLASS
                        COLOR 0 0 0
                        NAME "Fylke flate"
                        OUTLINECOLOR 255 255 255
                        SYMBOL "horizontal"
            END
END
In my getCapabilities file all the correct SRS tags are displayed like this:
- <Layer queryable="1" opaque="0" cascaded="0" noSubsets="0">
  <Name>layer_74</Name>
  <Title>Fylke flate</Title>
  <Abstract>For å hente dette tema via WMS må ein nytte layer_74 som verdi i LAYER parameter</Abstract>
  <SRS>EPSG:4326</SRS>
  <SRS>EPSG:25831</SRS>
  <SRS>EPSG:25832</SRS>
  <SRS>EPSG:25833</SRS>
  <SRS>EPSG:25834</SRS>
  <SRS>EPSG:25835</SRS>
  <SRS>EPSG:27391</SRS>
  <SRS>EPSG:27392</SRS>
  <SRS>EPSG:27393</SRS>
  <SRS>EPSG:27394</SRS>
  <SRS>EPSG:27395</SRS>
  <SRS>EPSG:27396</SRS>
  <SRS>EPSG:27397</SRS>
  <SRS>EPSG:27398</SRS>
  <SRS>EPSG:32631</SRS>
  <SRS>EPSG:32632</SRS>
  <SRS>EPSG:32633</SRS>
  <SRS>EPSG:32634</SRS>
  <SRS>EPSG:32635</SRS>
  <SRS>EPSG:102132</SRS>
  <SRS>EPSG:102133</SRS>
  <SRS>EPSG:102134</SRS>
  <SRS>EPSG:102135</SRS>
  <LatLonBoundingBox minx="-0.952145" miny="57.7524" maxx="31.9287" maxy="71.5653" />
  <BoundingBox SRS="EPSG:32633" minx="-77249.9" miny="6.4483e+06" maxx="1.11456e+06" maxy="7.94045e+06" />
- <Style>
  <Name>default</Name>
  <Title>default</Title>
- <LegendURL width="20" height="15">
  <Format>image/png</Format>
  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://adaptiveutv.avinet.no/wms.aspx?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=layer_74&format=image/png" />
  </LegendURL>
  </Style>
  </Layer>
Now I am connection to some other external WMS service that use ARCIMS, and I can see there that the SRS (EPSG code) is not put on each layer, but on the ?service level??
My question is: What is the correct way of dooing this according to the WMS standard? Should each SRS be on each layer or on the ?service level??
Best regards
Sture
