GetFeatureInfo from Oracle: no coordinates
Arjen de Korte arjendk at GMX.NET
Wed Jul 12 08:20:55 EDT 2006
Hello Mapserver users,
I'm trying to get Mapserver to give me a GetFeatureInfo result from
Oracle. I do get an XML document back, with the attributes and bounding
box in it, but *without* the coordinates!
So I do get a valid XML response, starting with <msGMLOutput> and
followed by the bounding box (<gml:Box>) and the attributes, but it does
not contain feature coordinates like <gml:MultiPolygon>.
We are using MS4W 1.5.3 and Oracle 9i Locator (no Spatial extensions).
In the mapfile the layer is defined by:
LAYER
  NAME test1
  METADATA
   "ows_title" "Test 1"
   "gml_include_items" "all"
   "wms_extent" "0 300000 300000 600000"
  END
  PROJECTION
   "init=epsg:28992"
  END
  STATUS ON
  TYPE POLYGON
  MAXSCALE 50000
  CONNECTIONTYPE oraclespatial
  CONNECTION "adk/adk at domain"
  DATA "geometry from test1 using unique ID srid 90112 relate version
  9i"
  DUMP true
  TEMPLATE "../templates/rivers_query_header.html"
  TRANSPARENCY 50
  CLASS
   NAME "Test 1"
   COLOR 0 100 0
  END
END
This is the URL I use for the request:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/geolocator/service/out.map&service=WMS&version=1.1.1&request=GetFeatureInfo&srs=EPSG:28992&bbox=174800,604995,178736,607363&info_format=application/vnd.ogc.gml&layers=bebgeb,water,test1&query_layers=test1&x=280.999999999999&y=70&width=615&height=370
Does anybody have a suggestion how to fix this?
Regards,
Arjen.
