Failed to draw layer error with mysql points
Sarah Parrott
parrott.sarah at GOOGLEMAIL.COM
Wed Jul 12 13:46:56 EDT 2006
I'm trying to get point data out of mysql to display on a map. I'm using
the following .ovf file, which I've tested using ogrinfo and seems to work
fine.
<OGRVRTDataSource>
<OGRVRTLayer name="test_gis">
<SrcDataSource>MYSQL:test_gis,user=root,password=mypword,host=
127.0.0.1,port=3306,tables=boxes</SrcDataSource>
<SrcSQL>SELECT fid, x, y FROM boxes</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="x" y="y" z="z" />
</OGRVRTLayer>
</OGRVRTDataSource>
When I go to the jsp that draws the map I get these errors:
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.JasperException: Failed to draw layer named 'test_gis'.
org.apache.jasper.servlet.JspServletWrapper.handleJspException(
JspServletWrapper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(
JspServletWrapper.java:375)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
javax.servlet.ServletException: Failed to draw layer named 'test_gis'.
org.apache.jasper.runtime.PageContextImpl.doHandlePageException(
PageContextImpl.java:858)
org.apache.jasper.runtime.PageContextImpl.handlePageException(
PageContextImpl.java:791)
org.apache.jsp.boxes.dartmoor_005fpoints_jsp._jspService
(dartmoor_005fpoints_jsp.java:74)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
JspServletWrapper.java:332)
root cause
java.lang.UnknownError: Failed to draw layer named 'test_gis'.
edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(Native Method)
edu.umn.gis.mapscript.mapObj.draw(mapObj.java:382)
(dartmoor_005fpoints_jsp.java:56)
I've tried loads of different things in the .map file (below) but I still
end up with the same problem. Does anyone know what I'm going wrong?
Thanks,
Sarah
Map file:
MAP
NAME DARTMOOR_POINTS
STATUS ON
SHAPEPATH "/usr/local/apache-tomcat-5.5.17/webapps/ROOT/boxes/"
EXTENT 250000.000000 57000.000000 260000.000000 70000.000000
SIZE 400 400
WEB
IMAGEPATH "/usr/local/apache-tomcat-5.5.17/webapps/ROOT/temp/"
IMAGEURL "/temp/"
END
LAYER
NAME "test_gis"
STATUS ON
TYPE POINT
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
CONNECTIONTYPE OGR
CONNECTION "test_gis.ovf"
DATA "test_gis"
CLASS
NAME "boxes"
SYMBOL 0
COLOR 0 0 0
OUTLINECOLOR 255 0 0
END
END
END
JSP File:
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<%@ page import = "edu.umn.gis.mapscript.mapObj" %>
<%@ page import = "edu.umn.gis.mapscript.imageObj" %>
<% mapObj vMap;
String vMapName = "/usr/local/apache-tomcat-5.5.17
/webapps/ROOT/boxes/dartmoor_points.map";
vMap = new mapObj(vMapName);
String vMapFile = "/usr/local/apache-tomcat-5.5.17
/webapps/ROOT/boxes/dartmoor_points.mapfile";
vMap.setMappath(vMapName);
imageObj img = vMap.draw();
img.save(vMapFile,vMap);
<head>
</head>
<body>
Image:<br>
<image src="dartmoor_points.mapfile">
</body>
</html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060712/8ec9d995/attachment.html
