Does Mapserver 4.8.3 work with windows 2000 and IIS 5
Barend Köbben
kobben at ITC.NL
Thu Jul 13 03:26:02 EDT 2006
HI,
In my experience, you also need to:
-Go to IIS Manager
- Open "Web Service Extensions"
- Allow cgi-bin/mapserv.exe
- Restart web server
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of rock well
> Sent: 12 July 2006 19:18
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Does Mapserver 4.8.3 work
> Hey andrew thanks, for the reply, i guess its the IIS 5
> issue. When i copied the mapserv and the required dlls to
> 2003 with IIS 6 i was able to generate the map with no issues.
> Thanks for your time
> kris
> Andrew Krakowski <andrew at REFRACTIONS.NET> wrote:
> Hi Kris,
> Have you been able to generate the "No query
> information to decode.
> QUERY_STRING is set, but empty." message?
> Have you read the online IIS MapServer instructions?
> There are a couple
> you can find.
> I'm not sure the difference between IIS 5 and 6 but
> I've succeeded with
> MapServer 4.8.3 working on IIS 6.0 on XP.
> Create a cgi-bin directory in your Inetpub directory
> and copy the
> contents of the ms4w\Apache\cgi-bin directory into it.
> In IIS add this directory as a virtual directory to
> your web-site.
> Right-click Properties under the cgi-bin Virtual
> Directory and select
> Scripts and Executables for Executables permission in
> the Virtual
> Directory Tab.
> When you right click the mapserv.exe file in IIS and
> select Browse in
> IIS you should get the above message.
> Hope that helps; if not let me know.
> Andrew
> rock well wrote:
> > Hi all, i have posted this question earlier but had
> to luck ..... i have been trying to configure mapserver
> -4.8.3 on a windows 2000 machine with IIS 5. I tried
> different options like just having the basic libraries like
> proj,GD, regex. When i try to generate a map i always get a
> > CGI Error
> > The specified CGI application misbehaved by not
> returning a complete set of HTTP headers. The headers it did
> return are:
> > i tried it from php mapscript, from a normal html
> file same result .....
> > i dont know what wrong am i doing .... if anyone have
> configured mapserver with this configuration can you please
> suggest me, or any information might help ...
> > Thanks a lot for your time,
> > kris
> > Yahoo! Messenger with Voice. Make PC-to-Phone Calls
> to the US (and 30+ countries) for 2¢/min or less.
> Andrew Krakowski
> Programmer, Refractions Research Inc.
> ________________________________
> Want to be your own boss? Learn how on Yahoo! Small Business.
> <http://us.rd.yahoo.com/evt=41244/*http://smallbusiness.yahoo.
> com/r-index>
