Porjection and WMS
Frank Warmerdam warmerdam at POBOX.COM
Thu Jul 13 09:46:23 EDT 2006
Daniel Goetz wrote:
> What stands the PORJECTION-object in the MAP-object for (not in case of
> WMS)? In my understanding it defines the projetion of the output image that
> mapserver generates. Is this true?
Yes
 > And if so can I choose every procetion
> in the PROJECTION-object of the MAP-object regardless of the projection of
> the single layers?
Yes
> What stands the PROJECTION-object in the LAYER-object for (not in the case
> of a WMS)? In my understanding this should be the projection in which the
> input data are recorded. Is this true?
Yes
 > So for each LAYER there is
> definitively only one type of projection possible in fact the one in which
> the original input data are recorded.
Yes
Pretty easy so far!
> And now the case of a WMS-Server:
> What stands the PROJECTION-object in the MAP-object of a WMS-service for in
> contrast to the WMS_SRS parameter of the METADATA in the MAP-object? Is
> this the same as in "normal" mapserver applications and the
> PROJECTION-object gives the projection mapserver shall project its
> output-images? What is the difference between PROJECTION-object and WMS_SRS
> parameters in the MAP-object?
I suspect the projection on the map object in a WMS situation is what would
be used if no SRS is selected in the WMS request.  I believe the wms_srs
metadata is used in building the list of supported projections in the
capabilities document and may be used to validated selected SRS values.
> And what about the PROCETION-object and the WMS_SRS-metadata in the
> LAYER-objects? should this be the declaration of the "real" PROCETION/SRS
> the input-data are in? And what is the difference between PROJECTION and
> WMS_SRS in this case?
The PROJECTION block definately still needs to be the real projection of
the underlying data.  I believe normally the wms_srs metadata would be the
list of supported projections the layer can be returned in.  I'm not
sure why you would use a different list for the wms_srs values for layers
and the map as a whole.
I'm sorry my answers with regard to wms_srs are a bit vaguer than my
earlier answers.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
