tile4ms aborts due to DBF fields not matching
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Jul 13 10:34:18 EDT 2006
Richard,
All the files you want to add to a tileindex MUST have the same
attribute definitions and they must be in the same order. The first file
you add to the tileindex is records the attribute columns, their names,
types, and probably their widths, then as each additional file is added,
it is check against the original file and if it does not match you get
the error you are seeing. This is required by mapserver.
-SteveW
DrDik wrote:
> Hi - I've run this on OSNI data from Northern Ireland and get: Aborted. DBF
> fields do not match for file:<filename>, I figured this was an error in the
> data but I down loaded tiger data and get the same error.
> I have followed the exmaple at
> http://mapserver.gis.umn.edu/docs/reference/utilityreference/tile4ms with no
> luck. Any ideas?
> It likes 1 file ok. But 2 files causes the Abort error.
> please help - I'm totally stuck!
> Thanks
> Richard
