Performance improvement
Fernando Simon fsimon at UNIVALI.BR
Fri Jul 14 07:38:15 EDT 2006
Hi Antonio,
This issue is relate with your DATA definition. You are using NONE
token, and it's indicate for Mapserver Oracle driver to don't use any
spatial filter or spatial operator (SDO_FILTER or SDO_REALTE). Even that
you are in a little extent that just contains 100 records, the NONE
force to load all the 60.000 records in your case.
Another point, are you using a geodetic SRID? If yes the Oracle use more
internal mathematical functions to process the request.
I suggest to change NONE to FILTER in you layer definition to test the
performance. What is it the results when you change for FILTER? You can
try to rebuild your index too.
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Antonio Iandolo wrote:
> Hi all,
> I've set up MapServer with a 4 layers map on an Oracle10g database thru
> a native connection (not OGR).
> The largest layer (which takes about 40% of the total time) is a polygon
> type of about 60,000 records (with a spatial index on the geom column)
> which isn't involved in any queryBy* php_mapscript function (only
> $map->setExtent) and has this DATA definition:
>   DATA "GEOM FROM MYLAYER USING SRID 8307 NONE"
> The whole page takes about 9-11 seconds to be rendered, while the same
> php script (exactly the same, except for the mapfile), when interfacing
> ESRI shapefiles, (Oracle data come from ESRI thru shp2sdo.exe utility)
> takes less than 4 seconds in total...
> The most of time (about 80-90%) is taken by the $map->draw() method,
> where I supose it applies the spatial filter to determine which shapes
> are to be rendered...
> How could I improve these performance? Any suggestion/hint to check any
> bottleneck?
> My environment is:
> - Pentium 4 - 1.8GHz - 512MB RAM
> - Windows XP Professional SP1
> - Apache 2.0.55
> - MapServer 4.8.3
> - php 4.4.3-dev (MS4W 1.5.3)
> - php_mapscript_48.dll
> - Oracle10g (XE)
> Thanks in advance,
> Antonio
