R: [UMN_MAPSERVER-USERS] Performance improvement
Antonio Iandolo
aiandolo at GRUPPOAS.IT
Fri Jul 14 10:11:34 EDT 2006
Hi Fernando,
thanks for your answer.
I knew that the "NONE" clause wouldn't have been a good idea (the
executed query in msOracleSpatialLayerWhichShapes doesn't include any
spatial filter) but it actually is roughly the same:
1) "DATA GEOM FROM EDIFICI USING SRID 8307 NONE": about 8.522 seconds
2) "DATA GEOM FROM EDIFICI USING SRID 8307 FILTER": about 9.176 seconds
3) "DATA GEOM FROM EDIFICI USING SRID 8307 NONE VERSION 10g": about
8.594 seconds
4) "DATA GEOM FROM (SELECT GEOM FROM EDIFICI) USING SRID 8307 NONE":
about 8.115 seconds
Moreover I'm using an SRID 8307 since that's my data's coordinate system
(is there a way to permanently "translate" my data in order to "cut"
this overhead?)
Anyway this is my actual layer in the mapfile:
LAYER
NAME "Edifici"
STATUS DEFAULT
DATA "GEOM FROM EDIFICI USING SRID 8307 NONE"
TYPE POLYGON
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "XAFFADM/XAFF"
MAXSCALE 945248462
CLASS
NAME "myclass"
STYLE
SYMBOL 4
COLOR 131 0 0
OUTLINECOLOR 0 0 0
SIZE 2
MINSIZE 2
MAXSIZE 2
ANTIALIAS TRUE
END
END
END
Any other suggestion/hint?
Regards,
Antonio
> -----Messaggio originale-----
> Da: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Per conto di Fernando Simon
> Inviato: venerdì 14 luglio 2006 13.38
> A: MAPSERVER-USERS at LISTS.UMN.EDU
> Oggetto: Re: [UMN_MAPSERVER-USERS] Performance improvement
> Hi Antonio,
> This issue is relate with your DATA definition. You are using
> NONE token, and it's indicate for Mapserver Oracle driver to
> don't use any spatial filter or spatial operator (SDO_FILTER
> or SDO_REALTE). Even that you are in a little extent that
> just contains 100 records, the NONE force to load all the
> 60.000 records in your case. Another point, are you using a
> geodetic SRID? If yes the Oracle use more internal
> mathematical functions to process the request. I suggest to
> change NONE to FILTER in you layer definition to test the
> performance. What is it the results when you change for
> FILTER? You can try to rebuild your index too. Best regards.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Antonio Iandolo wrote:
> Hi all,
> I've set up MapServer with a 4 layers map on an Oracle10g database
> thru a native connection (not OGR).
> The largest layer (which takes about 40% of the total time) is a
> polygon type of about 60,000 records (with a spatial index on the geom
> column) which isn't involved in any queryBy* php_mapscript function
> (only
> $map->setExtent) and has this DATA definition:
> DATA "GEOM FROM MYLAYER USING SRID 8307 NONE"
> The whole page takes about 9-11 seconds to be rendered, while the same
> php script (exactly the same, except for the mapfile), when
> interfacing ESRI shapefiles, (Oracle data come from ESRI thru
> shp2sdo.exe utility) takes less than 4 seconds in total...
> The most of time (about 80-90%) is taken by the $map->draw() method,
> where I supose it applies the spatial filter to determine which shapes
> are to be rendered...
> How could I improve these performance? Any suggestion/hint to check
> any bottleneck?
> My environment is:
> - Pentium 4 - 1.8GHz - 512MB RAM
> - Windows XP Professional SP1
> - Apache 2.0.55
> - MapServer 4.8.3
> - php 4.4.3-dev (MS4W 1.5.3)
> - php_mapscript_48.dll
> - Oracle10g (XE)
> Thanks in advance,
> Antonio
