MapServer Reprojection
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Jul 14 11:23:04 EDT 2006
Quoting "Fawcett, David" <David.Fawcett at STATE.MN.US>:
> Ryan,
> Do you have projection blocks for the MAP and LAYER. I don't see one in
> the layer.
> David.
Sorry forgot to post that. Yes I have a projection block for the map. I have
also tried setting one for the layer as well, but no luck with any combination.
PROJECTION
"init=epsg:4326"
END
> -----Original Message-----
> My problem is that no matter what I have my SRS numbers set to my data
> will always be displayed the same what. What could I be missing that
> would cause MapServer's re-projection capabilities not to work.
> I have several tiled .tiff images that I georeference by lat/long values
> using: gdal_translate -a_ullr 180 0 210 -30 thm_dir_N-30_180.png
> thm_dir_N-30_180.tiff
> I am then displaying them in MapServer using:
> LAYER
> NAME "themis"
> STATUS ON
> TILEINDEX "thm_dir.shp"
> TILEITEM "location"
> TYPE RASTER
> DUMP TRUE
> METADATA
> wcs_name "THEMIS_Data"
> wcs_description "THEMIS dataset"
> wcs_label "THEMIS dataset"
> ows_srs "EPSG:4326"
> ows_extent "0 -90 360 90"
> wcs_resolution "150 150"
> wcs_size "2700 3197"
> wcs_formats "GEOTIFF"
> END
> END
> Here is what gdalinfo reports, but isn't it MapServer that does all the
> re-projection? So that fact that the Coordinate System here is blank is
> ok right?
> gdalinfo thm_dir_-30_000.tiff
> Driver: GTiff/GeoTIFF
> Size is 7680, 7680
> Coordinate System is `'
> Origin = (0.000000,0.000000)
> Pixel Size = (0.00390625,-0.00390625)
> Corner Coordinates:
> Upper Left ( 0.0000000, 0.0000000)
> Lower Left ( 0.0000000, -30.0000000)
> Upper Right ( 30.0000000, 0.0000000)
> Lower Right ( 30.0000000, -30.0000000)
> Center ( 15.0000000, -15.0000000)
> Band 1 Block=7680x1 Type=Byte, ColorInterp=Gray
> Overviews: 3840x3840, 1920x1920, 960x960, 480x480, 240x240
