How do you use proj-4.4.9
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Jul 14 13:01:29 EDT 2006
How is it not working?
Quoting Albert Anderson <bart_doggers at YAHOO.COM>:
> Hi All,
> I installed proj-4.4.9 on a lunix machine. I follow the directions step by
> step. It does seem to be work. What should I do. I have the projection in
> the layer and map. code is here.
> #This is Richland County Map Server
> NAME "Richland"
> SIZE 309 417
> UNITS DD
> IMAGECOLOR 189 202 222
> IMAGETYPE JPEG
> PROJECTION "init=epsg:26914"
> END
> SHAPEPATH "/home/mapdata/"
> EXTENT -97.338391 45.907505 -96.508389 46.717217
> and
> LAYER
> NAME "richland"
> STATUS default
> TYPE polygon
> DATA "RICH_bndy"
> END
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END
> END
> Can someone help me.
> Thanks,
> Albert
> Do you Yahoo!?
> Everyone is raving about the all-new Yahoo! Mail Beta.
