Mapscript CSharp (C#) Memory Leak?
Tamas Szekeres szekerest at GMAIL.COM
Sat Jul 15 19:21:32 EDT 2006
David,
I have been testing your project and found the similar problems with
your mapscript binaries, however found no problem using the CVS-HEAD
mapscript binaries. This issue may be dedicated to the following bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1743
was also fixed in the current (4.8.4) release.
Best Regards,
Tamas Szekeres
2006/7/13, David Lowther <dlowther at coordinatesolutions.com>:
> Hello All,
> I've been toying with the mapscript_csharp.dll in VS2005 and cannot even
> begin to tell you how thrilled I am to have it. Thanks SO much.
> I've encountered what I think might be a memory leak.
> The exception text that I get is below and the entire source code of the
> application is available at:
> http://www.coordinatesolutions.com/download/mapservertestvb.zip
> I get the exception after choosing ID from the drop down and clicking the
> map 15 times (why 15, I have no idea). When running the code from VS2005 the
> exception occurs at different places.
> Any ideas?
> David Lowther
> Coordinate Solutions, Inc.
> 501 N.E. 15th Street
> Oklahoma City, OK 73104
> 405.246.9396 (Voice)
> 405.227.0781 (Fax)
> See the end of this message for details on invoking
> just-in-time (JIT) debugging instead of this dialog box.
> ************** Exception Text **************
> System.AccessViolationException: Attempted to read or write protected
> memory. This is often an indication that other memory is corrupt.
>    at mapscriptPINVOKE.new_pointObj(Double jarg1, Double jarg2, Double
> jarg3, Double jarg4)
>    at pointObj..ctor(Double x, Double y, Double z, Double m)
>    at MapserverTestVB.Form1.Pixel2Geo(pointObj pt) in
> D:\Develop\MapserverTestVB\MapserverTestVB\Form1.vb:line
> 188
>    at MapserverTestVB.Form1.ID(pointObj ClickPt) in
> 109
>    at MapserverTestVB.Form1.PictureBox1_MouseUp(Object
> sender, MouseEventArgs e) in
> D:\Develop\MapserverTestVB\MapserverTestVB\Form1.vb:line 97
>    at System.Windows.Forms.Control.OnMouseUp(MouseEventArgs
> e)
>    at System.Windows.Forms.Control.WmMouseUp(Message& m,
> MouseButtons button, Int32 clicks)
>    at System.Windows.Forms.Control.WndProc(Message& m)
>    at
> System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
> m)
>    at
> System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message&
> m)
>    at System.Windows.Forms.NativeWindow.Callback(IntPtr
> hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
> ************** Loaded Assemblies **************
> mscorlib
>     Assembly Version: 2.0.0.0
>     Win32 Version: 2.0.50727.42 (RTM.050727-4200)
>     CodeBase:
> file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
> MapserverTestVB
>     Assembly Version: 1.0.0.0
>     Win32 Version: 1.0.0.0
>     CodeBase:
> file:///D:/Develop/MapserverTestVB/MapserverTestVB/bin/Debug/MapserverTestVB.exe
> Microsoft.VisualBasic
>     Assembly Version: 8.0.0.0
>     Win32 Version: 8.0.50727.42 (RTM.050727-4200)
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
> System
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
> System.Drawing
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
> System.Configuration
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
> System.Xml
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
> System.Runtime.Remoting
>     CodeBase:
> file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
> mapscript_csharp
>     Assembly Version: 0.0.0.0
>     Win32 Version: 0.0.0.0
>     CodeBase:
> file:///D:/Develop/MapserverTestVB/MapserverTestVB/bin/Debug/mapscript_csharp.DLL
> ************** JIT Debugging **************
> To enable just-in-time (JIT) debugging, the .config file for this
> application or computer (machine.config) must have the
> jitDebugging value set in the system.windows.forms section.
> The application must also be compiled with debugging
> enabled.
> For example:
> <configuration>
>     <system.windows.forms jitDebugging="true" />
> </configuration>
> When JIT debugging is enabled, any unhandled exception
> will be sent to the JIT debugger registered on the computer
> rather than be handled by this dialog box.
