Mapserver compile error
antti siukola siukola.antti at GMAIL.COM
Mon Jul 17 04:36:44 EDT 2006
Hi!
I'm compiling the most recent MapServer and I get this OGR related
error on make:
./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
rectObj, ms_ogr_file_info_t*)':mapogr.cpp:(.text+0x38e): undefined
reference to `OGRLineString::setPoint(int, double, double)'
:mapogr.cpp:(.text+0x3ac): undefined reference to
:mapogr.cpp:(.text+0x3ca): undefined reference to
:mapogr.cpp:(.text+0x3e8): undefined reference to
:mapogr.cpp:(.text+0x406): undefined reference to
`msOGRShapeToWKT':mapogr.cpp:(.text+0xa15): undefined reference to
`OGR_G_SetPoint_2D'
:mapogr.cpp:(.text+0xa65): undefined reference to `OGR_G_AddPoint_2D'
:mapogr.cpp:(.text+0xaf1): undefined reference to `OGR_G_AddPoint_2D'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
I found some info from mailing list archive:
"This generally means you have two copies of GDAL/OGR on your system.
MapServer is getting built using the include files from one, but linked
against the libraries of another.  I would suggest you try and strip the
older GDAL/OGR off completely, or muck around with the MapServer makefile
to ensure that only one version is getting used consistently.  Basically
fiddling with the order of -I include directives and -L library
paths." -Frank Warmerdam, warmerdam at pobox.com
So I ran make clean on gdal and recompiled it and then tried to
compile mapserver but got the same error again.
Regards,
Antti S
