Mapserver compile error
antti siukola siukola.antti at GMAIL.COM
Mon Jul 17 06:28:50 EDT 2006
Reply to myself
I got it to work after removing gdal packages that I was installed
from Ubuntus repository since they were the duplicates with my
manually installed gdal. So, after that I recompiled gdal manually and
compiled mapserver and copied the php_mapscript.so to the php
extension directory but then I get this error:
Warning: dl() [function.dl]: Unable to load dynamic library
'/usr/lib/php5/20041030/php_mapscript.so' - libgdal.so.1: cannot open
shared object file: No such file or directory
What now?
Regards,
Antti S
On 7/17/06, antti siukola <siukola.antti at gmail.com> wrote:
> Hi!
> I'm compiling the most recent MapServer and I get this OGR related
> error on make:
> ./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
> rectObj, ms_ogr_file_info_t*)':mapogr.cpp:(.text+0x38e): undefined
> reference to `OGRLineString::setPoint(int, double, double)'
> :mapogr.cpp:(.text+0x3ac): undefined reference to
> :mapogr.cpp:(.text+0x3ca): undefined reference to
> :mapogr.cpp:(.text+0x3e8): undefined reference to
> :mapogr.cpp:(.text+0x406): undefined reference to
> `msOGRShapeToWKT':mapogr.cpp:(.text+0xa15): undefined reference to
> `OGR_G_SetPoint_2D'
> :mapogr.cpp:(.text+0xa65): undefined reference to `OGR_G_AddPoint_2D'
> :mapogr.cpp:(.text+0xaf1): undefined reference to `OGR_G_AddPoint_2D'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> I found some info from mailing list archive:
> "This generally means you have two copies of GDAL/OGR on your system.
> MapServer is getting built using the include files from one, but linked
> against the libraries of another.  I would suggest you try and strip the
> older GDAL/OGR off completely, or muck around with the MapServer makefile
> to ensure that only one version is getting used consistently.  Basically
> fiddling with the order of -I include directives and -L library
> paths." -Frank Warmerdam, warmerdam at pobox.com
> So I ran make clean on gdal and recompiled it and then tried to
> compile mapserver but got the same error again.
> Regards,
> Antti S
