cant get my lavyers working w/my projection file
Pagurek,Debbie [NCR] Debbie.Pagurek at EC.GC.CA
Mon Jul 17 13:42:31 EDT 2006
see the 'important notes' section on http://mapserver.gis.umn.edu/docs/reference/mapfile/projection/?searchterm=projection and do some reading in general about projections.
You would never have 2 epsg codes in one layer in your mapfile.
The projection object in your layer defines what projection your shapefile is in.
The projection object in your overall map object defines how you want your overall map (all the layers) projected.
I can't help much more than this - you have to know your data and understand what projections your shapefiles are in natively and then understand the final projection you want your map to appear in.
D. Pagurek
  _____
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Monday, July 17, 2006 12:44 PM
To: Pagurek,Debbie [NCR]; Albert Anderson; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my projection file
 I still get the error.  Do I put both projections in the map obj. and layer? How would the coded the projection file and the 3 unprojection files?  I am confussed about that?
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS meters
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
PROJECTION
"init=epsg:26914"
"init=epsg:4326"
END
LAYER
    NAME "richland"
    STATUS default
    TYPE polygon
    DATA "RICH_bndy"
    PROJECTION "init=epsg:26914"
    END
    CLASS
      STYLE
            COLOR 238 220 130
      END
   END
END
LAYER
    NAME "boundary"
    STATUS default
    TYPE line
    DATA "RC_boundary_05"
    PROJECTION "init=epsq:4326"
    END
    CLASS
      STYLE
            COLOR 0 0 0
      END
   END
END
Thanks,
Albert
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at ec.gc.ca> wrote:
	you have a typo in what you just wrote - it should be epsG not epsQ - I hope you have epsG in your mapfile.
	The error that you're getting indicates that Mapserver can't find the epsg file so it can't find the epsg code.
	On windows in a typical ms4w installation, your epsg file should be in
	c:\ms4w\proj\nad\
	D. Pagurek
  _____
	From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
	Sent: Monday, July 17, 2006 11:45 AM
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: Re: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my projection file
	 I changed my units and my scale bar looks better. I still cant get my layers working. I put them on default and put
	    END
	in the map object and it didnt like that. I get an error like msProcessProjection(): Projection library error. no system list, errno: 2 . What else can I try?
	Thanks,
	Albert
	"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote:
		If your other layers are not projected, you mean that they are in 'geographic'. You still need to set a projection object for them.
		Try
		PROJECTION
		  "init=epsg:4326"
		END
		This is geographic with the datum set as WGS84. This might not be the proper settings for your data - you could have another datum... anyway - set this projection object in your mapfile to see if you can get it working. What will happen is that Mapserver will project these layers on the fly to match the projection in your MAP object.
		D. Pagurek
  _____
		Sent: Monday, July 17, 2006 11:12 AM
		To: Pagurek,Debbie [NCR]; MAPSERVER-USERS at LISTS.UMN.EDU
		 I add a projection map file of richland county.  The other layers that I have are unprojective files. The roads file is all the road in the county.  Right now they are not catagorized. Thats the way the other layers are.  I just want to get the projection file loaded which is and also my layers which are not.
		  Setting it to default didnt seem to work.
		Thanks,
		Albert
			perhaps you could provide a bit more information to us. What is the native projection of the roads, boundary line, and etc... layers? If it isn't in the same projection as specified in your MAP object,
			PROJECTION
			  "init=epsg:26914"
			END
			then you also need to specify the projection in the layer object.
			you also might want to try to put STATUS DEFAULT for the roads, boundary etc and that way they will ALWAYS be ON. If status is set to ON you have to make sure that your URL specifies layers=layername in order for it to be on.
			Hope this helps,
			D. Pagurek
  _____
			Sent: Friday, July 14, 2006 4:58 PM
			Subject: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my projection file
			 I got my projection file working but I cant see to get my layers working like roads, boundary line, and etc...  Can someone look at my code and help me.  Thanks!
			---Codes-------
			<body>
			  <form method=POST action="/cgi-bin/mapserv">
			    <input type="submit" value="Click to initialize">
			    <input type="hidden" name="program" value="mapserv">
			    <input type="hidden" name="map" value="/home/mapdata/richland.map">
			    <input type="hidden" name="mapext" value="626173.309834 5085113.091715 694065.960556 5176735.212592">
			    <input type="hidden" name="zoomsize" size="2" value="2">
			    <input type="hidden" name="layers" value="boundary roads sections">
			  </form>
			 </body>
			</html>
			<input type="checkbox" name="layer" value="boundary" [boundary_check]/>
			  County Boundary <br />
			  &nbsp;
			  <input type="checkbox" name="city" value="city" />
			  City Boundary <br />
			  &nbsp;
			  <input type="checkbox" name="township" value="township" />
			  Township<br />
			  &nbsp;
			  <input type="checkbox" name="layer" value="sections" [sections_check]/>
			  Section Lines </span><br />
			  <br />
			  <font color="green"><span class="style2">&nbsp;Land</span></font><br />
			  <span class="style4">
			  &nbsp;
			  <input type="checkbox" name="layer" value="parcels" [parcels_check]/>
			  Parcels <br />
			  &nbsp;
			  <input type="checkbox" name="parcelslables" value="parcelslables" />
			  Parcels Labels</span><br />
			  <br />
			  <font color="red"<span class="style2">&nbsp;Transportation</span></font><br />
			  &nbsp;
			  <input type="checkbox" name="layer" value="roads" [roads_check]/>
			  County/City Roads <br />
			  &nbsp;
			  <input type="checkbox" name="addresslabels" value="addresslabels" />
			  Address Labels</span> </p>
			 <p class="style1"><font color="brown"><span class="style2">&nbsp;Backgrounds</span></font><br />
			 &nbsp;
			 <input name="aerial" type="checkbox" id="aerial" value="aerial" />
			  Aerial Photos</span></p>
			NAME "Richland"
			SIZE 309 417
			UNITS miles
			IMAGETYPE JPEG
			END
			SHAPEPATH "/home/mapdata/"
			EXTENT 626173.309834 5085113.091715 694065.960556 5176735.212592
			# Symbol for drawing fat lines
			SYMBOL
			     NAME "BigLine"
			     TYPE ELLIPSE
			     POINTS 1 1 END
			END
			# Symbol for drawing dashed lines
			SYMBOL
			     NAME "DashedLine"
			     TYPE ELLIPSE
			     POINTS 1 1 END
			     STYLE 10 10 END
			END
			# Symbol for drawing spots
			SYMBOL
			     NAME "Circle"
			     FILLED true
			     TYPE ellipse
			     POINTS 1 1 END
			END
			# Web object
			WEB
			  TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
			  IMAGEPATH '/var/www/htdocs/tmp/'
			  IMAGEURL '/tmp/'
			END
			# Reference map
			REFERENCE
			     IMAGE "/home/mapdata/richland.gif"
			     SIZE 136 152
			     EXTENT -97.228391 45.907505 -96.628389 46.717217
			     STATUS ON
			     COLOR -1 -1 -1
			     OUTLINECOLOR 0 0 0
			END
			# Scalebar
			SCALEBAR
			     LABEL
			          COLOR 0 0 0
			          ANTIALIAS true
			          SIZE small
			     END
			     POSITION lr
			     INTERVALS 5
			     STATUS embed
			     SIZE 144 5
			     STYLE 0
			     UNITS MILES
			     BACKGROUNDCOLOR 0 255 0
			     COLOR 128 128 128
			     OUTLINECOLOR 0 0 255
			     TRANSPARENT off
			END
			LAYER
			    NAME "richland"
			    STATUS default
			    TYPE polygon
			    DATA "RICH_bndy"
			    END
			    CLASS
			      STYLE
			            COLOR 238 220 130
			      END
			   END
			END
			LAYER
			    NAME "boundary"
			    STATUS on
			    TYPE line
			    CLASS
			      STYLE
			            COLOR 0 0 0
			      END
			   END
			END
			LAYER
			    NAME "roads"
			    STATUS on
			    TYPE line
			    DATA "roads_shp"
			    CLASS
			      STYLE
			            COLOR 255 0 0
			      END
			   END
			END
			LAYER
			    NAME "sections"
			    STATUS on
			    TYPE line
			    DATA "RC_sections_05"
			    CLASS
			      STYLE
			            COLOR 255 130 171
			      END
			   END
			END
			LAYER
			    NAME "parecles"
			    STATUS on
			    TYPE line
			    DATA "RC_parcels_05"
			    CLASS
			      STYLE
			            COLOR 0 0 0
			      END
			   END
			END
			END
			__________________________________________________
			Do You Yahoo!?
			Tired of spam? Yahoo! Mail has the best spam protection around
			http://mail.yahoo.com
  _____
		See the all-new, redesigned Yahoo.com. Check it out. <http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview>
  _____
  _____
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min. <http://us.rd.yahoo.com/mail_us/taglines/postman7/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/f0bf0a1b/attachment.html
