Mapserver compile error
antti siukola
siukola.antti at GMAIL.COM
Tue Jul 18 02:04:33 EDT 2006
Hi!
As Ubuntu doesn't have ld.so.conf and it doesn't use /usr/local but
/usr only I solved this by compiling gdal with --prefix=/usr. Thank's
Aaron! You pointed me to the right direction!
Antti S
On 7/17/06, Aaron Racicot <aaronr at ecotrust.org> wrote:
> Antti,
> You will need to tell your system where to find the gdal dynamically
> loaded library after install. I believe that it usually ends up in
> /usr/local/lib/ and if it is not part of your LD_LIBRARY_PATH then you
> can either:
> 1) Update LD_LIBRARY_PATH in your environment settings to include the
> location of libgdal.so.1
> 2) Add the path for libgdal.so.1 to /etc/ld.so.conf and run
> /sbin/ldconfig
> Hope this helps...
> Aaron
> | Aaron Racicot | aaronr at ecotrust.org |
> | GIS Programmer | 503.467.0759 |
> | e c o t r u s t |
> | Jean Vollum Natural Capital Center |
> | 721 NW Ninth Avenue |
> | Suite 200 |
> | Portland, OR 97209 |
> | www.ecotrust.org |
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of antti siukola
> Sent: Monday, July 17, 2006 3:29 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Mapserver compile error
> Reply to myself
> I got it to work after removing gdal packages that I was installed from
> Ubuntus repository since they were the duplicates with my manually
> installed gdal. So, after that I recompiled gdal manually and compiled
> mapserver and copied the php_mapscript.so to the php extension directory
> but then I get this error:
> Warning: dl() [function.dl]: Unable to load dynamic library
> '/usr/lib/php5/20041030/php_mapscript.so' - libgdal.so.1: cannot open
> shared object file: No such file or directory
> What now?
> Regards,
> Antti S
> On 7/17/06, antti siukola <siukola.antti at gmail.com> wrote:
> > Hi!
> > I'm compiling the most recent MapServer and I get this OGR related
> > error on make:
> > ./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
> > rectObj, ms_ogr_file_info_t*)':mapogr.cpp:(.text+0x38e): undefined
> > reference to `OGRLineString::setPoint(int, double, double)'
> > :mapogr.cpp:(.text+0x3ac): undefined reference to
> > :mapogr.cpp:(.text+0x3ca): undefined reference to
> > :mapogr.cpp:(.text+0x3e8): undefined reference to
> > :mapogr.cpp:(.text+0x406): undefined reference to
> > `msOGRShapeToWKT':mapogr.cpp:(.text+0xa15): undefined reference to
> > `OGR_G_SetPoint_2D'
> > :mapogr.cpp:(.text+0xa65): undefined reference to `OGR_G_AddPoint_2D'
> > :mapogr.cpp:(.text+0xaf1): undefined reference to `OGR_G_AddPoint_2D'
> > collect2: ld returned 1 exit status
> > make: *** [shp2img] Error 1
> > I found some info from mailing list archive:
> > "This generally means you have two copies of GDAL/OGR on your system.
> > MapServer is getting built using the include files from one, but
> > linked against the libraries of another. I would suggest you try and
> > strip the older GDAL/OGR off completely, or muck around with the
> > MapServer makefile to ensure that only one version is getting used
> > consistently. Basically fiddling with the order of -I include
> > directives and -L library paths." -Frank Warmerdam,
> > warmerdam at pobox.com
> > So I ran make clean on gdal and recompiled it and then tried to
> > compile mapserver but got the same error again.
> > Regards,
> > Antti S
