Eclipse MapServer libmapscript.so: cannot open shared object
file
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Wed Jul 19 12:40:30 EDT 2006
Quoting Norman Barker <nbarker at ittvis.com>:
> -----Original Message-----
> When trying to create a java application using eclipse i get the
> following
> error:
> java.lang.UnsatisfiedLinkError: libmapscript: libmapscript.so: cannot
> open
> shared object file: No such file or directory
> Here is my code:
> import edu.umn.gis.mapscript.*;
> import java.io.*;
> public class HelloServlet {
> public static void main(String[] args) {
> System.loadLibrary("mapscript");
> mapObj map;
> imageObj image;
> map=new
> mapObj("/var/www/html/mapserver/htdocs/display.map");
> map.setProjection("init=epsg:4326");
> image=map.draw();
> image.save("test.png",map);
> Ryan,
> You need to add the path variable to eclipse, so in eclipse do the
> following
> Run -> Run -> (select your configuration) -> Environment -> add a
> variable called path and set it to /usr/local/lib (or /usr/lib)
> Similary in Tomcat, or JBoss, you need to add -Djava.library.path=... to
> run.bat
> Norman
thank you but still no luck i am getting the same error message, and i am
running Apache on Fedora Core 5 if that helps any.
