Again c# Unable to load DLL (mapscript)
Paolo Corti pcorti at GMAIL.COM
Thu Jul 20 13:10:56 EDT 2006
Hi
I like MapServer, I have started to use it only since some days.
What I would like to do is to use the c# connector with .NET 1.1
But since 2 days I have very big troubles to let it work, I always get the
"Unable to load DLL (mapscript)" and I can't go on.
I found several 3ds in this forum with my same problem, but none of them
were helpfull for me. I tried to check missing dependencies, I tried to set
the PATH env, I tried to copy dlls under system32, all without success.
I first tried with the precompiled binaries distribution, then I downloaded
an map server installation toolkit (mapserver-4.8.3-2-msvc71-buildk-kit.zip
from http://hobu.stat.iastate.edu/mapserver/build_output/: 391 Mb!!!) and I
compiled myself -with success- mapscript_csharp.dll.
But when I create a stupid consol application with:
mapObj map = new mapObj(@"C:\ms4w\apps\sample\sample1.map");
I am always getting the same message: Unable to load DLL (mapscript)
I would be very happy to use C# with MapServer, as I do with ArcIMS (since
several years) but I just can't start....
I am starting to think to write (in C#) a .NET Connector to the CGI Map
Server...
Thanks in advance if you will help me!
View this message in context: http://www.nabble.com/Again-c--Unable-to-load-DLL-%28mapscript%29-tf1975214.html#a5419753
Sent from the Mapserver - User forum at Nabble.com.
