CGI Qlayer,Qstring variables usage
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Jul 21 14:56:54 EDT 2006
If you're doing just straight string equality tests then just do:
qlayer=states&qitem=state&qstring=ND
No need for funky qstrings in that case.
Steve
>>> rock well <rockwell_001 at YAHOO.COM> 7/21/2006 11:03:51 AM >>>
Hey david,
Thanks for your reply, i tried this but it didnt work. I am going to give you the complete link that we are using. Actually we are trying to query a states layer from the shape file and display just the north dakota state. So the link we are using are
http://localhost/scripts/mapserv.exe?MODE=map&MAP=c:/Inetpub/scripts/stateswms.map&CONTEXT=c:/Inetpub/wwwroot/mapserverdata/map_files/contextmap.xml&LAYERS=states&QLAYER=states&QITEM=state&QSTRING=('[state]'='ND')
any suggestions please ...
Thanks for your time and effort ...
kris
"Fawcett, David" <David.Fawcett at state.mn.us> wrote:
Kris,
This may not quite work, but it should be closer. Try something like:
http://pathtomapserv.exe?MODE=itemnquerymap&LAYERS=layer1&QLAYER=layer1&QITEM=colname&QString=('[colname]'='value')
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of rock well
Sent: Thursday, July 20, 2006 5:49 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] CGI Qlayer,Qstring variables usage
Hello all,
I was trying to query one of the layers from a shape file in the url, i am used map as the mode and gave the layer name for Qlayer, column name for Qitem and QString. Part of the URL looks like
http://pathtomapserv.exe?MODE=map&LAYERS=layer1&QLAYER=layer1&QITEM=colname&QString=("colname=value")
the map is displayed but it didnt filter the layer with the given querystring variables ....
Is there something missing, can anyone suggest with something ...
Thanks for your effort and time ....
kris
Do you Yahoo!?
Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
