Please help me with buffer in JavaMapscript!!!!
Reyes, Mariano
mreyes at SISCAT.COM.AR
Fri Jul 21 16:43:15 EDT 2006
I have ld.so.conf with line /usr/local/lib
Thank anyhow
Mariano Reyes
Buenos Aires, Argentina
_____
De: Alejandro Rico [mailto:jarg58 at gmail.com]
Enviado el: viernes, 21 de julio de 2006 17:29
Para: Reyes, Mariano
CC: MAPSERVER-USERS at lists.umn.edu
Asunto: Re: [UMN_MAPSERVER-USERS] Please help me with buffer in
JavaMapscript!!!!
Hi !!!
try to put in your /etc/ld.so.conf the line /usr/local/lib
and then run ldconfig, this let mapserver find the libraries needed to
execute properly.
On 7/21/06, Reyes, Mariano <mreyes at siscat.com.ar
<mailto:mreyes at siscat.com.ar> > wrote:
I have a problem with shapeObj.buffer( int i ), when call buffer I get this
error:
Exception in thread "main" java.lang.UnknownError: GEOS support is not
available
My code is:
pointObj punto = new pointObj( 250, 250, 0 );
lineObj line = new lineObj();
line.add(punto);
shapeObj shape = new shapeObj( mapscriptConstants.MS_SHP_ARCM );
shape.add( line );
shapeObj buff = shape.buffer( 200 );
Then I try compiler mapserver with geos, and in make test of mapscript/java
I have this message of error:
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x400a89b0, pid=30009, tid=1075228800
# Java VM: Java HotSpot (TM) Client VM ( 1.4.2_11-b06 mixed mode )
# Problematic frame:
# C [libc.so.6+0x729b0]
Please help me!!!!
Thank You!!!!
Mariano Reyes
Alejandro Rico
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060721/631ec158/attachment.html
