problems drawing highway symbols
Todd Fagin
tfagin at COORDINATESOLUTIONS.COM
Fri Jul 21 19:20:50 EDT 2006
Greetings list,
I am quite new to MapServer, so please bear with me on this one. Currently,
I have a layer called highways and I am attempting to label each highway
with an appropriate highway symbol. I have both gifs and pngs of the
symbols I want to use and I am borrowing code from a map file that I know
has worked in the past. I have attempted to do this several different ways.
The first method receives an error that states: "Attempted to read or write
protected memory. This is often an indication that other memory is corrupt."
This is using the code that has worked in a previous map file (I do not know
what version of MapServer was used, though. I am using the latest version).
Below is an example of what I am doing in the map file:
CLASS # Interstate Anno
MINSCALE 850000
SYMBOL "interstate.png"
EXPRESSION "IS"
COLOR 0 0 0
LABEL
TYPE BITMAP
MINDISTANCE 200
COLOR 255 255 255
SIZE tiny
POSITION CC
buffer 4
END
END
I know that the problem is the interstate.png because when I comment that
one line out, everything works (except, I do not get my symbol, of course).
I have attempted to change the permissions on the file, the directory in
which it is in, etc., but to no avail.
I have also tried an alternative method in which I create a symbol in the
symbol file and reference it.
Here is what I have done:
SYMBOL
NAME "Interstate"
TYPE PIXMAP
IMAGE "interstate.png"
END
When I reference this symbol in the symbol file, my map builds without any
errors, but my symbols still do not display.
Any suggestions would be greatly, greatly appreciated.
Thank you,
Todd Fagin
Coordinate Solutions, Inc.
501 N.E. 15th St.
Oklahoma City, OK 73104
405.246.9396 (Voice)
405.227.0781 (Fax)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060721/90892de1/attachment.html
