Adding Labels to a Vector Map with Java Mapscript
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sat Jul 22 05:29:25 EDT 2006
Can you post a sample generated image with only this layer on and your
fontset file?
You could also try to remove mindistance and to set the layer's status
to MS_DEFAULT.
Regards,
Umberto
On 7/21/06, Alejandro Rico <jarg58 at gmail.com> wrote:
> Hi !!!
> I'm working with a vector map made in Java Mapscript, with 2 layers, and i
> need that one of them has labels to identify a way, but when the program
> runs, mapserver draws a very little ununderstandable labels, and it doesn't
> take the font size change. Someone can help me with this??? thanks.
> here's my code:
> Capa = new layerObj(Mapa);
> Capa.setName("Vias");
> Capa.setType(mapscriptConstants.MS_LAYER_LINE);
> Capa.setStatus(mapscriptConstants.MS_ON );
> String Comando = new String("the_geom FROM (select gid,
> the_geom, nomb_comun||' '||nomvial as Nombre FROM "+Localidad+" WHERE codigo
> IN ("+CodigoVia+","+CodigoInterseccion+")) AS ViasMapa
> USING UNIQUE gid USING SRID=-1");
> Capa.setData(Comando);
> Capa.setLabelitem("Nombre");
> Capa.setConnection("user=geotrans dbname=Geotrans
> host=localhost");
> Capa.setConnectiontype (mapscriptConstants.MS_POSTGIS);
> Clase = new classObj(Capa);
> Estilo = new styleObj(Clase);
> Estilo.setColor(new colorObj(255,0,0,0));
> labelObj Etiquetas = new labelObj();
> Etiquetas.setSize(18);
> Etiquetas.setColor(new colorObj(0,255,255,0));
> Etiquetas.setType(mapscriptConstants.MS_TRUETYPE);
> Etiquetas.setAntialias(mapscriptConstants.MS_TRUE );
> Etiquetas.setPosition(mapscriptConstants.MS_CL);
> Etiquetas.setPartials(mapscriptConstants.MS_FALSE);
> Etiquetas.setMindistance(300);
> Etiquetas.setFont("vera");
> Clase.setLabel(Etiquetas);
> Mapa.draw().save("/usr/local/tomcat/webapps/geotrans/Mapas/mapaAcc",null);
> Alejandro Rico
