Adding Labels to a Vector Map with Java Mapscript
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Sun Jul 23 09:00:18 EDT 2006
Try this modifications:
Capa = new layerObj(Mapa);
            Capa.setName("Vias");
            Capa.setType(mapscriptConstants.MS_LAYER_LINE);
            Capa.setStatus(mapscriptConstants.MS_ON );
            String Comando = new String("the_geom FROM (select gid,
the_geom, nomb_comun||' '||nomvial as Nombre FROM "+Localidad+" WHERE
codigo IN ("+CodigoVia+","+CodigoInterseccion+")) AS ViasMapa USING
UNIQUE gid USING SRID=-1");
            Capa.setData(Comando);
            Capa.setLabelitem("Nombre");
            Capa.setConnection("user=geotrans dbname=Geotrans host=localhost");
            Capa.setConnectiontype (mapscriptConstants.MS_POSTGIS);
            Clase = new classObj(Capa);
// CHANGE FROM HERE
            Clase.setName('Pick a name');
// comment out the style
//            Estilo = new styleObj(Clase);
//            Estilo.setColor(new colorObj(255,0,0,0));
// and use this to set the color instead
            Clase.setColor(new colorObj(255,0,0,0));
// END OF CHANGE
            labelObj Etiquetas = new labelObj();
            Etiquetas.setSize(18);
            Etiquetas.setColor(new colorObj(0,255,255,0));
            Etiquetas.setType(mapscriptConstants.MS_TRUETYPE);
            Etiquetas.setAntialias(mapscriptConstants.MS_TRUE );
            Etiquetas.setPosition(mapscriptConstants.MS_CL);
            // CHANGE: comment this too
            //Etiquetas.setPartials(mapscriptConstants.MS_FALSE);
            //Etiquetas.setMindistance(300);
            Etiquetas.setFont("vera");
            Clase.setLabel(Etiquetas);
            Mapa.draw().save("/usr/local/tomcat/webapps/geotrans/Mapas/mapaAcc",null);
You could also try to save the map to a file to make sure everything
got setup properly in mapscript. To do this simply call
Mapa.save('filename'); then post the map file to the list.
Regards,
Umberto
On 7/23/06, Alejandro Rico <jarg58 at gmail.com> wrote:
> > Hi !!!
> > I try with your suggestions but it doesn't work.
> > here's a sample image of the map generated, and the fontset file
> > thanks !!!
> > On 7/22/06, Umberto Nicoletti < umberto.nicoletti at gmail.com> wrote:
> > > Can you post a sample generated image with only this layer on and your
> > > fontset file?
> > > You could also try to remove mindistance and to set the layer's status
> > > to MS_DEFAULT.
> > > Regards,
> > > Umberto
> > > On 7/21/06, Alejandro Rico < jarg58 at gmail.com> wrote:
> > > > Hi !!!
> > > > I'm working with a vector map made in Java Mapscript, with 2 layers,
> and i
> > > > need that one of them has labels to identify a way, but when  the
> program
> > > > runs, mapserver draws a very little ununderstandable labels, and  it
> doesn't
> > > > take the font size change. Someone can help me with this???  thanks.
> > > > here's my code:
> codigo
> ViasMapa
> > > > USING UNIQUE gid USING SRID=-1");
> > > > host=localhost");
> > > >             Etiquetas.setMindistance (300);
> > > > Alejandro Rico
> > Alejandro Rico
> Alejandro Rico
