CGI Qlayer,Qstring variables usage
Daniel Goetz
madprof at GMX.CH
Mon Jul 24 02:21:11 EDT 2006
I have two suggestions (but I am not quiet sure whether this is right):
first I think you should put the value for "mode" from "map" to "query" or "itemquery" or itemnquery" or something like that.
Second: I could not understand your qstring expression. In my little mapserver project I have the possibility to search for features that have the same values in a special database column. For example: When I want to search for all objects that have the value "13" in the database-column "TM_NR" then my qstring looks like this: "qstring=TM_NR=13". Very simple, but it works.
Perhaps you could try this. But as I mentioned I don't really know whether it works or not.
Good luck and bst regards
Daniel
-------- Original-Nachricht --------
Datum: Fri, 21 Jul 2006 09:03:51 -0700
Von: rock well <rockwell_001 at YAHOO.COM>
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] CGI Qlayer,Qstring variables usage
> Hey david,
> Thanks for your reply, i tried this but it didnt work. I am going
> to give you the complete link that we are using. Actually we are trying to
> query a states layer from the shape file and display just the north dakota
> state. So the link we are using are
> http://localhost/scripts/mapserv.exe?MODE=map&MAP=c:/Inetpub/scripts/stateswms.map&CONTEXT=c:/Inetpub/wwwroot/mapserverdata/map_files/contextmap.xml&LAYERS=states&QLAYER=states&QITEM=state&QSTRING=('[state]'='ND')
> any suggestions please ...
> Thanks for your time and effort ...
> kris
> "Fawcett, David" <David.Fawcett at state.mn.us> wrote:
> Kris,
> This may not quite work, but it should be closer. Try something like:
> http://pathtomapserv.exe?MODE=itemnquerymap&LAYERS=layer1&QLAYER=layer1&QITEM=colname&QString=('[colname]'='value')
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of rock well
> Sent: Thursday, July 20, 2006 5:49 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] CGI Qlayer,Qstring variables usage
> Hello all,
> I was trying to query one of the layers from a shape file in the
> url, i am used map as the mode and gave the layer name for Qlayer, column
> name for Qitem and QString. Part of the URL looks like
> http://pathtomapserv.exe?MODE=map&LAYERS=layer1&QLAYER=layer1&QITEM=colname&QString=("colname=value")
> the map is displayed but it didnt filter the layer with the given
> querystring variables ....
> Is there something missing, can anyone suggest with something ...
> Thanks for your effort and time ....
> kris
> Do you Yahoo!?
> Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
> Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great
> rates starting at 1¢/min.
Echte DSL-Flatrate dauerhaft für 0,- Euro*. Nur noch kurze Zeit!
"Feel free" mit GMX DSL: http://www.gmx.net/de/go/dsl
