Mapscript Installation Problems
Thomas Hammerlund tom at MAPLINK.JP
Mon Jul 24 06:13:20 EDT 2006
I'm almost set up with Mapserver, but I keep getting an error when I test
php/mapscript.
I modified the demo_init.html file here:
<! -- Replace the value of the parameter below to the full path to the
temporary directory where MapServer will write temporary files.  Make sure
the web user account can write to this directory.-->
<input type="hidden" name="map_web_imagepath"
value="/var/www/html/itasca/graphics/">
and here:
<!-- Change the "value" of map to the full path and name of your mapfile.
For Windows users, add the drive letter in front of the path.  ex:
"c:/inetpub/wwwroot/itasca/demo.map" -->
<input type="hidden" name="map" value="/var/www/html/itasca/demo.map">
I also edited the demo.map file's WMS_ONLINERESOURCE value, and SHAPEPATH to
"/data".
However pointing the browser to test_draw_map.phtml gives me an error and
this is displayed:
numlayers; // phpinfo(); // // RENDER MAIN MAP // // Note: If you get errors
with the saveWebImage() call below, then make sure // that the directory
specified by IMAGEPATH in the .MAP file exists and is // writable by the
httpd user. // $img = $map->draw(); $url = $img->saveWebImage(MS_PNG, 0, 0,
0); printf("\n", $url, $map->width, $map->height); // // LEGEND // $img =
$map->drawLegend(); $url = $img->saveWebImage(MS_PNG, 0, 0, 0); printf("
I'm running Fedora 5.  Does anyone have any ideas what the problem could be?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060724/fe197fc1/attachment.html
