Line Width Problem {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Mon Jul 24 08:56:43 EDT 2006
Check http://mapserver.gis.umn.edu/docs/howto/cartosymbols
Look for cartoline and linejoin.
Bye
Zoltan
On Mon, 24 Jul 2006, Thomas Hammerlund wrote:
> Thank you for your reply.
> I use the 'circle' symbol for when the line is less than 1. I did try using
> circle for all widths, but it produces the same result. I think when the
> line is about to reach the edge and it stops drawing, the half-circle is
> what is left and that's what is seen. (Does that make sense?) I think it's
> like if you put two quarters together. There's space in between them.
> Is there a different symbol that might work better?
> ----- Original Message -----
> From: "Blammo" <bob.basques at ci.stpaul.mn.us>
> To: "Thomas Hammerlund" <tom at MAPLINK.JP>
> Sent: Monday, July 24, 2006 4:00 PM
> Subject: Re: Line Width Problem
> >> Hi Everyone,
> >> I'm having a little trouble with my line widths. I'm using tiled
> >> layers, and when lines with a with greater than 1 reach the edge, they
> >> don't connect properly. Does anyone have a solution for this? Below is
> >> the class section for this layer.
> >> CLASS
> >> MAXSCALE 25000
> >> MINSCALE 0
> >> Name style1
> >> EXPRESSION /l_bbbag|l_bbbaf/
> >> STYLE
> >> COLOR 240 184 53
> >> WIDTH 3
> >> END
> >> END
> >> Is there maybe a symbol I could use that would go beyond the tile?
> > Did you try it with a SYMBOL defined in the style?
> > My wide lines look like this for example:
> > LAYER
> > TYPE LINE
> > CLASS
> > STYLE
> > SYMBOL 'circle'
> > SIZE 5
> > END
> > COLOR 175 175 175
> > NAME 'Local Roads'
> > END
> > END
