WMS time question
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Thu Jul 27 12:39:52 EDT 2006
Sounds like the correct approach.
Best regards,
Bart
Yewondwossen Assefa wrote:
> Hi There,
>  We could add a support by supporting "wms_timeitem_min" and
> "wms_timeitem_max" (mutually exclusive with wms_timeitem) and doing
> the following for different time values passed in the wms TIME
> parameter :
>   - single time for example: ...&TIME=2004-10-12&... would give
> (`[time_field_min]` <= `2004-10-12`) and  `[time_field_max]` >=
> `2004-10-12`)
>   - multiple values (2004-10-12, 2004-10-13) would give
> ((`[time_field_min]` <= `2004-10-12` and  `[time_field_max]` >=
> `2004-10-12`) OR (`[time_field_min]` <= `2004-10-13`) and
> `[time_field_max]` >= `2004-10-13`))
>   - single range : 2004-10-12/2004-10-13 transforms to
> ((`[time_field_min]` <= `2004-10-12`) AND (`[time_field_max]` >=
> `2004-10-13`))
>   - multiple ranges (2004-10-12/2004-10-13, 2004-10-15/2004-10-16)
> transform to ((`[time_field_min]` <= `2004-10-12`) AND
> (`[time_field_max]` >= `2004-10-13`)) OR ((`[time_field_min]` <=
> `2004-10-15`) AND (`[time_field_max]` >= `2004-10-16`))
>  Is this acceptable ? Do you see other ways ? I have added a bug
> related to this http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1849
> Later,
> Eijnden, Bart van den (AGI) wrote:
>> Hi Assefa,
>> so e.g. you would have (DD-MM-YYYY):
>> ROAD_SEGMENT_ID        MIN_DATE        MAX_DATE
>> 1                01-01-2006        01-04-2006
>> 2                01-03-2006        01-06-2006
>> etc.
>> So these represent validity, the road segment is valid/existant
>> between MIN_DATE and MAX_DATE.
>> So if I want a map with the situation of 01-05-2006, 1 would not be
>> on it, but 2 would be.
>> If I would want a map with the situation of 15-03-2006 until
>> 15-04-2006, both would be on it.
>> Does this make sense?
>> Best regards,
>> Bart
>> -----Oorspronkelijk bericht-----
>> Van: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Yewondwossen Assefa
>> Verzonden: donderdag 27 juli 2006 3:35
>> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>> Onderwerp: Re: [UMN_MAPSERVER-USERS] WMS time question
>> Bart,
>> Bart van den Eijnden (OSGIS) wrote:
>>> Hi list,
>>> looking through the Mapserver WMS time HOWTO I wondered one thing,
>>> it is
>>> only possible to have 1 timeitem, a DB column which contains the
>>> date/time. Ofcourse this is pretty okay for satellite images (in a
>>> tileindex) which are taken every X days/months.
>>> But what happens to road network segments (geometries in Oracle Spatial
>>> for instance) which have a minimum date and a maximum date? So you
>>> need to
>>> specify 2 timeitems (one min and one max) for that. Was this use
>>> case just
>>> not implemented?
>>   What would the min/max date represent : the valid time extents or
>> simply 2 time fields on which we can do a query ?
>> The wms request allows to  send a time value that is then compared to
>> the value inside the timeitem. Would you expect to be able to compare
>> the time request between the 2 timeitmes defined ?
>>> Best regards,
>>> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
