Map File Problem?
M.L. Jackson mljacks2 at HOTMAIL.COM
Fri Jul 28 14:42:21 EDT 2006
I think that the problem is not client side at all.  The errors generated
appear to come directly from the server.  It could be the http server
(Apache Tomcat) because I've also had deployment issues lately which I think
I have resolved.  I'm just really not sure at all about the errors.  I guess
I will have some trial and error debugging to do.  I will also try the
shp2img utility.  Thanks.  :-) Any other suggestions would be great as well.
>From: Randy James <rjames57 at YAHOO.COM>
>Reply-To: Randy James <rjames57 at YAHOO.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Map File Problem?
>Date: Fri, 28 Jul 2006 10:16:43 -0700
>The shp2img utility comes with mapserver. Could the problem be in your http
>server rather than Mapserver? Or even a client side browser problem?
>   Randy
>"M.L. Jackson" <mljacks2 at HOTMAIL.COM> wrote:
>   Where is the shp2img utility? Does it come with mapserver or do you have
>to
>download it? Sorry for the newbie questions but thanks for your help.
> >From: Jeff McKenna
> >Reply-To: Jeff McKenna
> >Date: Fri, 28 Jul 2006 11:46:39 -0400
> >have u tried using the shp2img utility, to see if your mapfile is ok? I'd
> >first make sure your mapfile is fine, then worry about your application.
> >jeff
> >M.L. Jackson wrote:
> >>The thing is.......the errors occur at random. If the errors weren't
> >>related to some central problem, then the same error should keep
>occuring
> >>until I fix it before any other errors are displayed. Instead each time
> >>the server is restarted and the application is run a new error
>supposedly
> >>in the map file is displayed.
> >>>From: Jeff McKenna
> >>>Date: Fri, 28 Jul 2006 10:55:45 -0400
> >>>I'm not sure about your random problem...but you might want to check
>the
> >>>errors section of the mapserver documentation page, and battle those
> >>>errors one by one: http://mapserver.gis.umn.edu/docs/error
> >>>jeff
> >>>M.L. Jackson wrote:
> >>>>Hi. I am running mapserver 4.6.0-beta1 with Java Mapscript on Tomcat.
> >>>>While working on my project, I have encountered a weird series of
> >>>>errors. Everytime I restart the server and try to run my application,
>I
> >>>>get an error indicating what appears to be any random line in the map
> >>>>file. Most of the time the errors generated make absolutely no sense.
> >>>>Among the errors generated are "projection not named" and "major axis
> >>>>or radius = 0 or not given". The other errors are generally any line
> >>>>number with a piece of the map file indicated. Thanks for your
>replies.
> >Jeff McKenna
> >DM Solutions Group Inc.
> >http://www.dmsolutions.ca
>_________________________________________________________________
>Don’t just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
>Yahoo! Music Unlimited - Access over 1 million songs.Try it free.
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
