Problems with querybypoint and shapelib
Frederico Lucca fredlucca at GMAIL.COM
Thu Jun 1 13:37:11 EDT 2006
Umberto,
Yes, I build using --with-threads --with-ogr --with-proj
Now i will try to make the interface with a newer version of swig.
I have read your article and I will try to follow him step by step.
Another question, I still need to syncronize my code?
Thanks,
Fred
On 6/1/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> How did you compile mapserver and java mapscript (give the configure
> arguments exactly)? Did you use the -use-threads argument?
> Have you read the docs on mapserver web site (search for java):
> http://mapserver.gis.umn.edu/docs/howto/javamapscript ?
> Regards,
> Umberto
> On 6/1/06, Frederico Lucca <fredlucca at gmail.com> wrote:
> > Hello list,
> > After a couple of request at same time my Tomcat broke with this error:
> > # Java VM: Java HotSpot(TM) Server VM (
> > 1.5.0_06-b05 mixed mode)
> > # Problematic frame:
> > # C [libc.so.6+0x6c91c] mempcpy+0x1c
> > --------------- T H R E A D ---------------
> > Current thread (0x6d049348): JavaThread "http-8080-Processor23" daemon
> > [_thread_in_native, id=11434]
> > siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00000000
> > Stack: [0x6c06d000,0x6c0ee000), sp=0x6c0ebad4, free space=506k
> > Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
> C=native
> > code)
> > C [libc.so.6+0x60b08] _IO_sgetn+0x28
> > C [libc.so.6+0x5548e] _IO_fread+0x8e
> > C [libmapscript.so+0x6b968] msSHPOpen+0x478
> > C [libmapscript.so+0x6bba5] msSHPOpenFile+0x55
> > C [libmapscript.so+0x6bdce] msShapeFileLayerOpen+0x8e
> > C [libmapscript.so+0x95341] msLayerOpen+0x61
> > C [libmapscript.so+0x86362] msQueryByPoint+0x172
> > C [libmapscript.so+0x57f4d] layerObj_queryByPoint+0x4d
> > C [libmapscript.so+0x57fc1]
> > Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByPoint+0x61
> > j
> > edu.umn.gis.mapscript.mapscriptJNI.layerObj_queryByPoint(JJJID)I+0
> > --------------- S Y S T E M ---------------
> > OS:Mandriva Linux release 2007.0 (Cooker) for i586
> > uname:Linux 2.6.16-1mdksmp #1 SMP Fri May 19 19:16:59 CEST 2006 i686
> > libc:glibc 2.4 NPTL 2.4
> > I have already heard about a problem with swig and java, how can I fix
> it if
> > this is the problem?
> > Could somebody help me?
> > Thanks in advance,
> > Fred
> > "Everything under the sun is in tune
> > But the sun is eclipsed by the moon"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060601/bd417481/attachment.html
