queryByAttributes and postgis
Francesco Cadili
fcadili at NGI.IT
Thu Jun 1 14:05:06 EDT 2006
Bertsch wrote:
> Have a look at your SQL statement you are trying to compare column
cod_concio
> to a string with the value '3523 AND cod_concio = 6087 AND cod_concio =
> 6092'. Take care on the qotes you are defining in the data object.
> mfg
> Clemens
http://www.nabble.com/queryByAttributes+and+postgis-t1717138.html#a4664620
> Sent from the Mapserver - User forum at Nabble.com.
I have found the problem. In the mapserver archive there was a message
"http://www.nabble.com/Re%3A+queryByAttributes+PostGIS+Problem-t1350724.html#a3614291"
of Paul Moen:
> It seems that 4.8.2 does not include a fix for bug 1629. I
downloaded and applied the patch and
> my query works as it did in 4.6.2.
> The patch is available by going to
http://mapserver.gis.umn.edu/bugs/index.cgi and entering
> 1629 for the bug number.
> I downloaded the patch, named it mapostgis.patch and saved it in my
mapserver-4.8.2 source
> directory.
> To apply the patch, in the mapserver-4.8.2 source directory, I typed
in terminal,
> patch mappostgis.c mappostgis.patch
> I then recompiled mapserver and queryByAttributes works as it did in
4.6.2.
> Hopefully someone will find this useful.
> Paul Moe
I have done some further testing and I have discover that the problem
was fixed on version 4.8.3.
The version that I used was a bugged one (version 4.8.1).
Thank you for your help.
Francesco
