Error in displaying raster in tileindex shape SOLVED
Gambin Dejan Dejan.Gambin at PULA.HR
Fri Jun 2 03:04:20 EDT 2006
I solved the problem, maybe it can help someone to shortly explain:
The problem was that my raster layer with tileindex shapefile had the
same name as the name of the tileindex shapefile. So I had something
like:
LAYER # katastar
  NAME         "katastar_index"
  STATUS       OFF
  TYPE         RASTER
  TILEINDEX "katastar_index"
  TILEITEM "LOCATION"
END
After changing NAME to something else everything was OK.
Thanks to everyone
dejan
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf
> Of Frank Warmerdam
> Sent: Thursday, June 01, 2006 9:55 PM
> To: Gambin Dejan
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Error in displaying raster
> in tileindex shape
> Gambin Dejan wrote:
> > Hi,
> > I have created tileindex shapefile with my rasters using
> gdaltindex.
> > When trying to show the raster layer I get the following
> errors in my
> > php error log:
> > [01-Jun-2006 16:11:12] PHP Warning:  [MapServer Error]:
> msDrawMap():
> > Failed to draw layer named 'katastar_index'.  in
> > /var/www/pmapper1/incphp/map.php on line 311 [01-Jun-2006 16:11:12]
> > msRASTERLayerOpen(): Attempt to open a RASTER layer, but
> this is only
> > supported after a raster query.
> Dejan,
> What version of MapServer are you using?  I think we used to
> run into this in some circumstances with MapServer 4.6 but it
> should be fixed in 4.8.  I can't remember exactly what causes
> it to happen though.
> If you are using 4.8, please provide me a complete but
> minimal test case to reproduce the problem via bugzilla.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF,
> http://osgeo.org
