How to make MS4W to support epsg:3067?
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jun 2 12:52:45 EDT 2006
Rahkonen Jukka wrote:
> Hi,
> Registered epsg code 3067 is referring to ETRS-UTM zone 35N, and is effectively just a synonyme to epsg:25835 with the only difference that it 3067 is defined to be valid for the whole Finnish territory, that is more than 6 degrees wide. Now I wonder how could I make Mapserver from MS4W delivery to understand this code? The newest FWTools do already support epsg:3067. Using 25835 instead is usually OK, but some (over)correct softwares give error messages when the natural 6 degrees wide area is exceeded.
Jukka,
It should be possible to just copy the PROJ.4 "epsg" init file from
FWTools to the appropriate place in MS4W.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
