Apps timing out
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Mon Jun 5 09:17:47 EDT 2006
You might also want to test with MS4W 2.0 or 1.5.4, and use the
mapserver version 4.9 upgrade package to see if your error also occurs
with 4.9.
jeff
Roland Martin wrote:
> Hi,
> I wonder if anyone's come across this before (I couldn't find anything
> related to Mapserver & this error on the t'interweb)...
> Since upgrading from MS4W 1.2.2 (Mapserver 4.6.1) to 1.5.1 (Mapserver
> 4.8.3 ) a few weeks ago, I've been getting the following error on 2 of
> the apps:
> (70007)The timeout specified has expired: ap_content_length_filter:
> apr_bucket_read() failed
> Which is logged in the error.log file on loading - it effectively means
> that the page stays with the spinner for about 20 minutes before it loads.
> I've gone through the code with a fine-tooth comb, and it now only seems
> to be occurring in Internet Explorer - which leads me to suspect that
> either (or both) the map file or the HTML may contain some unclosed tags
> or dodgy code (although that's slightly surprising as they're all built
> from the same template).
> Anyone have any ideas? I'll send the related files if that sounds like
> the most likely cause.
> Ta,
> Roland.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
