[Fwd: Re: WFS gurus . . . .]
Bob Basques bob.basques at CI.STPAUL.MN.US
Tue Jun 6 11:26:17 EDT 2006
All,
Some progress,
We've managed to add to the PROJ4 EPSG list and verified that it works
with a WMS output.  So the new EPSG code we added works just fine as a
WMS call.
Next we tried the same with a WFS call and got an INIT error, which was
traced to OGR, so we then (tried to) build Mapserver without GDAL only
to learn that WFS requires it to build.  So my question is, where is OGR
grabbing it's Projection info from?  From the code it looks like there
is a parser in place, but we couldn't find where it was being referenced.
Thanks for all help
bobb
> 	-----Original Message-----
> 	From: Bob Basques [mailto:bob.basques at ci.stpaul.mn.us]
> 	Sent: Mon 05-Jun-06 11:29
> 	To: Kralidis,Tom [Burlington]
> 	Cc:
> 	Subject: Re: [Fwd: Re: WFS gurus . . . .]
> 	Ok, last private one . . .
> 	Is would be nice to get options for our neighboring Counties as well.  I
> 	work on a couple of other metro area committees and Mapping projects
> 	that plan to use MapServer, and I would just as soon use a common format
> 	across all projects if possible.   I'm not expecting you or anyone else
> 	to do the work, only expressing the idea in case you come up with some
> 	sort of automatic solution of some sort.  :c)
> 	I can do the grunt work if needed, but I'm not sure I'm the one to
> 	define what the other County info that is supposed to be used for this
> 	or not.  There is a County Projection data list at the State of
> 	Minnesota Dept. of Transportation as well.
> 	If some sort of leg work is needed on this end I'm available to group
> 	things together to add the County information for the State of Minnesota
> 	for example.
> 	bobb
> 	Kralidis,Tom [Burlington] wrote:
> 	> Good question.
> 	> What's your actual projection definition?
> 	> CubeWerx (http://www.cubewerx.com/) holds the 42xxx projection
> 	> definitions.  We've worked with them to establish codes which are not
> 	> natively in EPSG.  I've cc'd Craig here for info.
> 	> ..Tom
> 	>> From: UMN MapServer Users List=20
> 	>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bob Basques
> 	>> Sent: Monday, June 05, 2006 10:38 AM
> 	>> To: MAPSERVER-USERS at LISTS.UMN.EDU
> 	>> Subject: [UMN_MAPSERVER-USERS] [Fwd: Re: WFS gurus . . . .]
> 	>> =20
> 	>> =20
> 	>> Ok, we'll try that.
> 	>> =20
> 	>> Any rule-of-thumb for assigning an arbitrary code?
> 	>> =20
> 	>> bobb
> 	>> =20
> 	>> =20
> 	>> -------- Original Message --------
> 	>> Subject:     Re: WFS gurus . . . .
> 	>> Date:        Mon, 5 Jun 2006 10:32:23 -0400
> 	>> From:        Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
> 	>> Reply-To:    Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
> 	>> =20
> 	>> =20
> 	>> =20
> 	>>> =3D20
> 	>>> I'm trying to get a WFS output in a local coordinate system. =3D20 =20
> 	>>> Everything=3D20  works just fine with a EPSG code, but our coordinate =
> 	>>> system is not in=3D20  the list.  Do we need to add it in in more =
> 	> than=20
> 	>>> one location?  We're=3D20  using a few extensions that all=20
> 	>> seem to have=20
> 	>>> their own=3D20  version of a EPSG=3D20
> 	>>> code list, different formats and everything.
> 	>> =20
> 	>> What's your projection parameters?  If it's indeed not an=20
> 	>> EPSG code, you'll need to add this to your proj install's=20
> 	>> epsg file, then cite that EPSG code in your WFS request. =3D20
> 	>>> All I need is to be able to get the WFS output with a same=20
> 	>>> coordinate=3D20 system BBOX.  Can I get around the EPSG=20
> 	>> requirement with=20
> 	>>> some form of=3D20 fakery?  Can the GML be output with a=20
> 	>> MODE=3D3D option=20
> 	>>> perhaps, in it's=3D20 native coordinate system?
> 	>> =20
